chunlong Tan
Rep Power: 3 ![]() |
Dear all,
when I chosen Harmonic->Fluid Structure->Mechanical Coupling->Modal->Forced motion to conduct an flutter analysis. I found that there was no imformation about iteration time step. I'm wondering if this type of simulation is not related to the time step, or if I didn't find where to set the time step. Kind regards, Chunlong |
Wout Poncelet
Rep Power: 0 ![]() |
Dear Chunlong,
Given that you're performing a flutter analysis and you mention the harmonic, I assume you're running a NLH simulation? Is my understanding correct? In that case, there is no need to specify a time step (just a CFL number). The NLH method will solve the NS-equations in the frequency domain. Once your simulation is converged, you will be able to reconstruct your solution in space and time, here you can specify the time step and the number of time steps you want to reconstruct. The imposed forced motion, in case of a NLH simulation, can be constant in time or defined with a given frequency/mean value/IBPA/Real and imaginary part. I hope this may help you. With best regards, Wout Poncelet |
chunlong Tan
Dear Wout,
Thank you, your answer has completely solved my confusion. Kind regards, Chunlong |
flutter analysis |
Postprocess: sampleDict works but creates no output folder | shock77 | OpenFOAM Post-Processing | 14 | November 15, 2021 08:27 |
Convergence problem of OF | WUYing | OpenFOAM Running, Solving & CFD | 2 | September 20, 2021 10:09 |
Setting up Lid driven Cavity Benchmark with 1M cells for multiple cores | puneet336 | OpenFOAM Running, Solving & CFD | 11 | April 7, 2019 00:58 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
