unsteady Boundary Condition ( user defined function) |
Rep Power: 4 ![]() |
Hey Guys,
I want to simulate a fluctuating flow, that flow through the Turbine ( just NGV). A sine function can describe the fluctuating pressure in the inlet good. So I want to use a unsteady Boundary condition at the inlet that change with time. But I find nowher the option to use a user defined function. I just can click at the absolute total pressure, change the parameter from constant to function and upload a graph. The sine function has the simple form: p = Amplitude*sine*(2*pi*frequence*time). greetings Hussein |
Colinda
Rep Power: 14 ![]() |
Hi Hussein,
Which environment are you using? Omnis or Fine? Which version? Best regards, Colinda |
#3 | |
Hi Colinda, iam using Omnis 5.2, the problem has solved. I Found the feature thx. There is another issue, in the manual/Omnis Environment/ Profil manager/Standard CSV Format/ the theta, that is defined there, is it the azimuthal angle ? And since I have a fluctuating flow I have a variation in the velocity angle within a range of ±40 degree. Where can I define these angle ? Because for example in the Inlet/subsonic/cylindrical/total quantities imposed/angle from axial direction or relative angle from axial direction and more, maybe I can define the velocity angle here ? I have attached a picture, there is alpha ( velocity angle) applied over the azimuthal angle. greetings Hussein |
problem has already solved
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 17:38 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
using METIS functions in fortran | dokeun | Main CFD Forum | 7 | January 29, 2013 04:06 |
