Home > Forums > Software User Forums > Fidelity CFD
Maximum Angular deviation permitted in directions other than spanwise
Like Tree2Likes
  • 1 Post By colinda1
  • 1 Post By Johan M
Old   April 4, 2022, 10:21
Default Maximum Angular deviation permitted in directions other than spanwise
Johan M
Johan M is on a distinguished road
Dear all,
I had seen omnis gave recommended ranges for different mesh criteria to identify the degree of mesh quality, seen attached. It gives a range for the maximum spanwise angular deviation but does not recommend a range for the overall max angular deviation (in directions besides spanwise). I would like to know if even the overall angular deviation should be < 40 degrees, or if it can exceed that value as long as the spanwise angular deviation is < 40 degrees.
Kind regards,
Johan
Johan M is offline   Reply With Quote
Old   April 11, 2022, 03:58
Default Span angular deviation
Colinda
colinda1 is on a distinguished road
The span angular deviation is used for detecting issues in the mesh generation process. AutoGrid generates the 3D mesh by stacking the different blade-to-blade meshes from the different flow paths. In some cases (due to an issue linked to the computation of the intersection of the blade with the flow paths, a difference of convergence of the blade-to-blade mesh smoother,...), it can happen that two adjacent mesh layers are not the same leading to a discontinuity in the 3D mesh. These discontinuities can be detected by the span angular deviation criteria and generally have a bad effect on the orthogonality criteria and that's why we recommend to remove them.
I hope this explains why the angular deviation is relevant in span direction and not in the blade-to-blade directions?
Best regards,
Colinda
Turboheld likes this.
colinda1 is offline   Reply With Quote
Old   April 11, 2022, 10:29
Johan M
Dear Colinda,
Thank you for the response! Although I admit I am still trying to understand how the dm/r-θ plane plotting actually works as it seems abit abstract to picture for me, I do roughly grasp the idea of wrapping 2-d blade to blade meshes on each spanwise meridional flow path to create a the 3-d blade from your explanation. In that sense I can sort of picture how the importance lies in the spanwise direction regarding angular deviation.
To confirm, is adjacent mesh layers referring to meridional flow paths that lie along the span?
Kind regards
Johan
Old   April 11, 2022, 10:39
Colinda
Dear Johan,
Indeed, with adjacent mesh layers we mean the blade-to-blade mesh on adjacent flow paths.
Best regards,
Colinda
Old   April 11, 2022, 12:09
Johan M
Dear Colinda,
Thank you for the confirmation and help
Kind regards
Johan
colinda1 likes this.
angular deviation, autogrid5, mesh quality, omnis
loading issue libraries:libsimpleFunctionObjects.so libsimpleSwakFunctionObjects.so immortality OpenFOAM Pre-Processing 15 April 7, 2024 13:35
Spanwise Angle deviation greater than 40 allenjohngeorge Fidelity CFD 3 December 30, 2018 02:11
OpenFoam "Permission denied" and "command not found" problems. iyidaniel@yahoo.co.uk OpenFOAM Running, Solving & CFD 11 January 2, 2018 07:47
Diverging solution in transonicMRFDyMFoam tsalter OpenFOAM Running, Solving & CFD 30 July 7, 2014 07:20
compressible flow in turbocharger riesotto OpenFOAM 50 May 26, 2014 02:47
