Home > Forums > Software User Forums > Fidelity CFD
reference pressure in Numeca
Like Tree1Likes
  • 1 Post By colinda1
Old   July 26, 2021, 06:58
Default reference pressure in Numeca
wwcs
abuya is on a distinguished road
Hey, guys. I'm learning Numeca recently. I have a question about the reference pressure in Numeca. What is the meaning of it? If the reference pressure is 1atm, and the inlet total pressure is 2atm. Should I set the inlet total pressure to be 1atm (2atm-1atm) or 2atm?
abuya is offline   Reply With Quote
Old   July 28, 2021, 13:48
Hamid Zoka
Hamidzoka is on a distinguished road
Hi;
In NUMECA Boundary values for pressure are absolute values and do not need to be expressed with respect to reference pressure.
The function of the mentioned reference pressure,together with reference temperature, is to calculate entropy and its value does not affect the results. As it is known, entropy is always measured with respect to a reference value and in thermodynamic processes its delta is important. So, These reference parameters can take any value.
Regards
Hamidzoka is offline   Reply With Quote
Old   July 29, 2021, 08:51
wwcs
Originally Posted by Hamidzoka View Post
Hi;
Regards
Thank you!
Old   August 2, 2021, 04:06
Colinda
colinda1 is on a distinguished road
I would like to add that apart from the entropy, the reference pressure is used at other places as well. This may be different for each solver. For example for the Fine™/Turbo solver this may be:
  • in the Boussinesq approximation for incompressible fluid,
  • in the outlet boundary condition for which the mass flow is imposed with pressure adaptation when the expert parameter MASPAO < 2,
  • in the definition of the heat transfer coefficient when the expert parameter HTCDEF is set to 2.
It is also used as a default gauge pressure for the preconditioning in case of low speed or incompressible flows.
Hamidzoka likes this.
colinda1 is offline   Reply With Quote
[OpenFOAM.org] Not found many .so files when installing OpenFOAM 6 lengjun OpenFOAM Installation 2 December 12, 2022 23:08
viscosity udf don't use correct temperature and strain rate rezvani Fluent UDF and Scheme Programming 8 May 27, 2021 06:40
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 75 August 20, 2018 06:37
reference pressure and compressible flow bingo10 CFX 0 September 11, 2013 08:32
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 01:34
