Home > Forums > Software User Forums > Fidelity CFD
About NLH in Numeca
Like Tree1Likes
  • 1 Post By Hamidzoka
Old   September 19, 2019, 14:52
Default About NLH in Numeca
newbie384 is on a distinguished road
Hi
I saw from NUMECA website that it is possible to use NLH to simulate the interaction between the rotor and the volute (see link below).
https://www.numeca.com/product/id/139
Does anyone know whether the simulation includes the full volute as well for the NLH method?
In the website, it mentions that only one blade passage is being solved.
I just wonder if that is the case, how can one get the flow field in the volute?
It will be very helpful if someone could kindly enlighten me a bit about the setup.
Thank you in advance.
newbie384 is offline   Reply With Quote
Old   September 26, 2019, 02:59
Hamid Zoka
Hamidzoka is on a distinguished road
Hi;
NLH of a impeller / volute has been presented in a paper by Numeca entitled as "The nonlinear harmonic method: from single stage to multi-row effects" published in International Journal of Computational Fluid Dynamics in 2013.
You may find useful hints there.
regards
Saeef likes this.
Hamidzoka is offline   Reply With Quote
FSI simulation of wind turbine blade using NLH method Ko_Shine Fidelity CFD 3 April 22, 2020 08:08
NLH with SA (Extended Wall Functions) Cappytbg Fidelity CFD 6 March 15, 2018 06:26
Nonlinear Harmonic (NLH) method in Numeca Tegegn Dejene Fidelity CFD 14 December 30, 2015 06:26
Parallel computation using NUMECA 6.1 BalanceChen Fidelity CFD 1 June 5, 2011 07:24
New NUMECA Forum Opened Jonas Larsson Main CFD Forum 0 February 16, 2003 11:25
