Home > Forums > Software User Forums > Fidelity CFD
Unsteady - Modal Coupling
Like Tree2Likes
  • 1 Post By Ko_Shine
  • 1 Post By AndrijaG
Old   November 16, 2018, 11:42
Default Unsteady - Modal Coupling
Ko Shine
Ko_Shine is on a distinguished road
I’ve been trying to run the FSI unsteady simulation using modal coupling method in FINE/Turbo (version 12.1). I used fct(time) to impose the generalized displacement for the mode shape. However, I got this message when I started the solver:
“! Error in the number of points for displacement profile, nData = 0”
What does this message exactly mean? I’ve given enough points for the displacement though.
I did run the same model using NLH method. There wasn’t any problem with that. The idea is to compare the two runs (unsteady and NLH). On a separate question, I’m also wondering if it is possible to change IBPA in unsteady mode in a same way as Harmonic mode.
Thank you.
Ko_Shine is offline   Reply With Quote
Old   March 15, 2020, 20:32
Andrija Grbavac
AndrijaG is on a distinguished road
Hey Ko_Shine,
did you solve the problem? I have the same problem and couldn't figure out how to fix it.
Best regards,
AndrijaG
AndrijaG is offline   Reply With Quote
Old   March 16, 2020, 06:27
Ko Shine
Yeah I solved that problem more than one year ago. In my case, there were two groups of patches that were coupled sharing the same mode shape file. I needed to group them together as a single patch.
I hope it helps!
colinda1 likes this.
Old   March 16, 2020, 20:42
Andrija Grbavac
Hey Ko_Shine,
thanks for your fast response. I'll try to fix it with that hint. Thank you!
FSI problem with system coupling: Fail to couple FLUENT sophieUNSW FLUENT 16 October 1, 2020 06:20
Difference between stagger/coupling iteration and coupling step Jiricbeng CFX 1 September 13, 2016 03:37
Coupling time duration, Coupling time steps Jiricbeng CFX 0 April 29, 2015 09:37
Star ccm 9.02 - unsteady flux dissipation correction fivos STAR-CCM+ 4 April 28, 2014 10:37
Unsteady flow- pressure velocity coupling Hooman Main CFD Forum 0 June 7, 2010 11:31
