March 5, 2018, 14:44 |
Aerodynamic coefficients
Andrea Visentini
Hi everybody,
this is my fist post in this forum, I have a problem with Numeca software. I have an aerodynamic profile in a simple domain, I have make the mesh ad start the solution with Fine Open. In the monitor compre the Lift and Drag force, my question is: can I see directly the value of the aerodynamic coefficients Cl and Cd? If so where? Tnk Andrea |
March 6, 2018, 16:16 |
Holger Dietrich
Rep Power: 15 |
Dear Andrea,
yes, it is given out by one of the standard files of the computation. Please have a look into the computation directory, at the bottom of the .wall file the computed lift and drag coefficient with its reference values is given out. You can easily access this file with any text editor. Please make sure that you have set in the FINE/Open GUI -> Computation Control -> Outputs to "External Flow". Kind regards Holger |
November 4, 2019, 02:30 |
cl and cd
veerappan
Rep Power: 7 |
after my computaion , i cant see cl and cd values ..its showing zero values , its not updating
November 13, 2019, 05:25 |
Colinda
Rep Power: 14 |
Did you activate the "compute force and torque" for the applicable solid patches in the solid boundary conditions page?
February 24, 2020, 05:30 |
Calculate aerodynamic coefficients with openfoam using only opensource programs | Xwang | OpenFOAM | 20 | May 20, 2016 12:26 |
Aerodynamic Coefficients | sukratu | OpenFOAM Programming & Development | 7 | August 26, 2015 12:15 |
Aerodynamic coefficients | daxterss | Fidelity CFD | 2 | April 10, 2012 03:20 |
[Fluent] Aerodynamic Forces and Coefficients in 180-grid | info_bahaider | FLUENT | 0 | January 4, 2012 05:28 |
Computing aerodynamic coefficients on bidimensional sections in 3D problems | Aragon | FLUENT | 0 | July 22, 2009 05:07 |
