October 27, 2017, 05:47 |
CF View azimuthal averaged solution error
Marco
Rep Power: 9 |
Hello
I am currently busy running simulations of a mixed-flow compressor impeller, but get an error when I want to view the azimuthal averaged solution. I get the following error: IO error in FileOpenProject: Input error in Run1_new_Run_1.12.3.me.cfv: cgns file 'Run' not found. Am I possibly missing a specific selection that one should make to view the azimuthal averaged solution? Any advice would be greatly appreciated. Kind regards Marco |
October 27, 2017, 09:07 |
Holger Dietrich
Rep Power: 15 |
I get a similiar, but not identical error in my case (....Input error in <filename>, Mesh base not found).
I guess in FINE/Turbo GUI you hit the CFView button in the top bar and checked the field "View the Azimuthal Averaged Solution"? I don't know why this happens, but I would recommend to start CFView without activating this field. In CFView you start in the 3D View, please select File -> Turbomachinery -> OK. In the top left view you can visualize the Azimuthal Averaged Solution, too. If you miss a quantity in the azimuthal view, which you want to post process you can double-click it in the 3D View and then start the turbomachinery mode. Variables selected this way and even user-defined quantities are available in the turbo view then. I hope this helps you to proceed. Kind regards, Holger Last edited by DarylMusashi; October 27, 2017 at 13:47. |
azimuthal, cfv, postprocessing |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 20:43 |
Errors in UDF | shashank312 | Fluent UDF and Scheme Programming | 6 | May 30, 2013 21:30 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 07:25 |
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." | sega | OpenFOAM Community Contributions | 12 | February 17, 2010 10:30 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 11:23 |
