Home > Forums > Software User Forums > Fidelity CFD
Define Hub and Shroud for imported CAD file
Like Tree1Likes
  • 1 Post By Hamidzoka
Old   May 10, 2016, 06:38
Default Define Hub and Shroud for imported CAD file
Daniel DA is on a distinguished road
Hi NUMECA users,
i have a question concerning the definition of my Hub and Shroud curves. I prepared a CAD-file of an impeller and imported it to AutoGrid 5. But now i dont have exact Hub and Shroud curves to select. Can i somehow manage to define them with surfaces or do i have to make them visible in the CAD-Model?
Thanks for your answers.
Regards Daniel.
Daniel DA is offline   Reply With Quote
Old   May 10, 2016, 06:51
Here you can see a picture of the imported file.
Old   May 10, 2016, 17:13
Hamid Zoka
Hamidzoka is on a distinguished road
You need to have hub and shroud curves the revolving of which makes hub and shroud surfaces respectively. regarding the blades it seems no problem.
regards
Hamidzoka is offline   Reply With Quote
Old   May 11, 2016, 04:34
Did you mean i just have to select all curves the build the surface, for example for Shroud, and than link them all to Shroud?
Or do i need an extra curve?
Anyway thanks for the answer, i´m working on it.
Old   May 11, 2016, 06:38
Hamid Zoka
It is simple. Let me explain it this way:
every revolved surface is constructed by revolving a curve. for example in a z r theta reference frame, if there is a revolved surface around z, there is a curve defined using z and r. you should find this curve.
one method is to intersect the revolved surface with a proper plane, e.g. ZR plane. do this for both hub and shroud surfaces.
Old   May 11, 2016, 06:52
Thanks a lot for you answer Hamizoka,
i got what you meant, but i have one last question:
Do you know if i can produce such a plan in CAD or should i do it in NUMECA?
Regards.
Old   May 11, 2016, 07:05
Hamid Zoka
This should be done in a 3D CAD modeler e.g. Catia, NX,...
regards
colinda1 likes this.
Old   May 18, 2016, 09:03
Colinda
colinda1 is on a distinguished road
Indeed it can be done in CAD or in NUMECA software, (IGG/AutoGrid5) whichever you prefer.
colinda1 is offline   Reply With Quote
hub and shroud curves steep variations Théo002 Fidelity CFD 0 March 24, 2016 13:42
pro/engineer -> turbogrid import file YIM SNAG PIL CFX 10 July 5, 2015 02:52
How is Hub to Shroud Line drawn in CFX by default? arunraj CFX 0 October 14, 2011 08:36
boundary conditions for hub and shroud Jasmine CFX 3 March 24, 2009 21:05
how to decide the shroud and hub line angel Fidelity CFD 4 April 1, 2003 03:39
