Home > Forums > Software User Forums > Fidelity CFD
Hexpress, move hanging nodes
Like Tree1Likes
  • 1 Post By colinda1
Old   September 17, 2015, 00:18
Question Hexpress, move hanging nodes
liyifei is on a distinguished road
I want to use Hexpress to generate unstructured mesh to make a computation on CFX, but there is always hanging nodes in the mesh. Hanging nodes are forbidden in CFX, so how can I move the hanging nodes in the mesh generated by Hexpress? If it's not possible to do so in Hexpress, what software I can use to complete this?
Thank you!
liyifei is offline   Reply With Quote
Old   September 21, 2015, 03:37
Colinda
colinda1 is on a distinguished road
You could use HEXPRESS/Hybrid instead. With a full-hex mesh in HEXPRESS it is not possible to avoid the hanging nodes unless you do not make any local refinements in the adaptation step. In HEXPRESS/Hybrid it is possible to create a hex-dominant mesh without hanging nodes. The resulting mesh may have also tets, prisms and pyramids.
liyifei likes this.
colinda1 is offline   Reply With Quote
Old   September 21, 2015, 11:37
Thanks for your reply!
I'm a beginner with Hexpress and Hexpress/Hybrid. In my experience, I think mesh made by Hexpress has higher quality than that made by Hexpress/Hybrid.
So as you know, I can't generate mesh without hanging nodes only with Hexpress, is it right? How can I move the hanging nodes made by Hexpress? Any software suggest?
I do try to generate mesh with Hexpress/Hybrid, but the boundary layer is not as good as Hexpress, if I use this software, what can I do to make better mesh with it?
Thanks so much for your help!
Old   September 21, 2015, 11:50
Colinda
Indeed HEXPRESS makes high quality meshes but indeed always with hanging nodes if you put local refinements in your mesh (and most often you need to).
You write that your boundary layer in HEXPRESS/Hybrid is not so good as in HEXPRESS. Maybe it is possible to show some pictures of the problematic boundary layer? It is difficult to know what could be done to improve it without seeing the problem.
Old   October 7, 2015, 10:18
Hey colinda1, me again!
I have tried to modify the mesh recently, and the mesh is good enough to make the calculation.
But there is still some problems I can't handle. I'm sorry that I don't know how to upload a picture. I want to make unstructured mesh in a turbine passage, the internal mesh in turbine has two periodical surfaces. Can I make a 1:1 grid on the two periodical surfaces with Hybrid?
Thanks!
Old   October 12, 2015, 12:32
Erwann
tdrerwann is on a distinguished road
Periodic matching is available in HEXPRESS but I understand from your previous posts that you want to avoid hanging nodes...
In HEXPRESS/Hybrid, periodic matching is expected for next year.
tdrerwann is offline   Reply With Quote
Old   October 12, 2015, 22:08
It's amazing that you know so much about these software.
Thanks for all your help!
cfx 14.5, hanging nodes, hexpress
Best way to handle hanging nodes in Fluent for LES? flotus1 FLUENT 4 December 16, 2013 04:32
hanging nodes in fluent; Zafer Zeren FLUENT 6 April 9, 2013 15:25
creating hanging nodes with ICEM CFD zafer CFX 0 May 17, 2006 04:36
hanging boundary nodes aman Main CFD Forum 0 October 18, 2005 11:12
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
