April 2, 2015, 21:15 |
Divergence occurs during simulation
aa
Rep Power: 14 |
Dear All,
I did simulation in waves involving multi-domain case problem. In the mesh management, I already set to be "no mesh deformation". However, the simulation was crashed in middle of running (pls kindly see the comments and the force monitoring in the attached files). Could you pls share your expert to solve the problem. Thanks in advance. Regards, Naid |
April 4, 2015, 11:27 |
Romain
Rep Power: 17 |
Did you witness high motion amplitudes ?
Was the wave field initialized in the whole domain ? Your simulation crashing so early on is a bit odd. It might be better for your boat/geometry/vessel to reach a steady state position and then turn the wave maker on. What kind of time step did you use (relative to your geometry length, and nominal speed) ? How many iterations per time step ? I have never used multi-domains in FineMarine so I have no experience on the subject... |
April 6, 2015, 10:24 |
romainRH
Rep Power: 14 |
Rombzh are you sure that to reach a steady state in calm water and then turn the waves on is faster and/or more stable than making the boat accelerate slightly (waves should not be initialize in the domain if 2dof are solved) Afitriadhy can you defined middle of running. Does the waves have reach the outlet or not ? Can you post a picture of wave elevation before your simulation diverged? |
April 6, 2015, 12:12 |
aa
Rep Power: 14 |
Hi Rombzh,
Thanks for your reply. So far, the amplitude of motion was not jump yet (only the force). Yes I set the wave to be generated from front (head-sea). I did multiple-domain involving ship to ship interactions. This case, I set for zero speed of ships. Then I do not need to run the ships with speed. Here, I used time laws as recommended by Numeca (manual book). I am looking forward to getting your further share in future especially for multiple-domain case. Tq |
April 6, 2015, 12:21 |
aa
Rep Power: 14 |
Hi RomainRH,
Thanks for the reply. Actually I set the storage every 100 (output results). However, the simulation has not reached yet to that stipulated time, then i can not open the CFView. Meaning to say, I can post you the wave elevation. Looking forward to getting your sharing experiences. |
April 7, 2015, 05:10 |
#6 | |
Romain
Rep Power: 17 |
Besides, if problems are to occur, it is more likely they will with a lot of unsteadyness, i.e when waves have reached the boat, so then you do not have to restart from scratch in case of a problem. I don't know if you're saving that much time, I just find it more convenient (and if you are modelling different wave conditions with the same grid, you don't have to redo the acceleration). Anyway here the boats are at rest so this "method" is useless, but I find it odd that the run crashes after only 2 seconds. I doubt the waves have reached the outlet or even the boats yet. afitriadhy, when you monitor the residuals, after how many iterations do they start blowing up ? What kind of minimum orthogonality you have for your grid ? Like romainRH said, monitor closely your run, and stop it when you see things are getting crazy. You'll then be able to post process your results with cfview (or check after how many time steps you run failed, and restart it with a lower maximum time step number so you're sure then run will stop before it crashes). |
Floating Point Exception Error | nyox | FLUENT | 11 | November 30, 2018 13:31 |
Huge file sizes when Running VOF simulation | aarratia | FLUENT | 0 | May 8, 2014 13:27 |
Discrete event simulation vs. fixed time (discrete time simulation) | jenjon | FLUENT | 0 | March 10, 2013 07:58 |
divergence of scaled residuals (steady simulation) | hanka | FLUENT | 6 | December 16, 2010 05:45 |
problems simulation ideal gas, divergence in AMG S | Ralf Schmidt | FLUENT | 11 | October 1, 2005 14:21 |
