Home > Forums > Software User Forums > Fidelity CFD
Connection of Hexpress grid and Autogrid 5 grid
Like Tree1Likes
  • 1 Post By colinda1
Old   November 18, 2014, 23:18
Question Connection of Hexpress grid and Autogrid 5 grid
Young G is on a distinguished road
Hi guys,
I am trying to connect inlet volute grids generated by Hexpress and stage grids generated by Autogrid in Hexpress.
Structured grid can be transformed into unstructured in Hexpress, and its shape and quality seem OK. But when I try to connect the interfaces of these two parts, I mean the outlet of volute and the inlet of stage, with R/S boundary condition, it fails.
Has someone succeded in doing the similar work?
Young G is offline   Reply With Quote
Old   November 22, 2014, 00:03
In terms of importing the geometrical file, only Parasolid can be chosen. But .x_t file takes meter as its unit, which means my volute is 1/1000 to my stage. So I have to scale it in hexpress to match my stage.
I doubt that scaling the geometry may be the reason for the failure of creating R/S interface.
However, building a volute large enough is impossible in SOLIDWORKS, because the volute is too big, approximately 1000m long.
I do need your help.
Old   November 24, 2014, 04:27
Talking
After being tortured by this problem for almost a week, I finally solve it.
I will note it here, in case it's helpful to others facing the same problem.
Tip 1:When you are generating the domain form geom file(.x_t), minimize the parameters as adviced by NUMECA. Precise geom will never hurt.
Tip 2: Never leave only one facet on one side of RS interface as the mannual said, neither too many!!! (It seems cutting one surface into 4 facets is also the main reason for former failure. 2 facets seems popular to this code.)
Old   December 1, 2014, 03:53
Colinda
colinda1 is on a distinguished road
Thank you for also posting your comments on how to solve it.
Indeed, when creating a domain from a parasolid file, it is good to make sure the triangulation settings are fine enough to define the geometry well. The minimum and maximum length may be divided by 100 and the curve and surface tolerances as well.
Indeed 1 face closed on itself at the rotor/stator interface is not ideal. In general I see no reason at all why 4 faces would not work. It is more likely something specific to your case that should be investigated in more detail if necessary to understand why it does not work.
But most important; it works now
Best regards,
Colinda.
Young G likes this.
colinda1 is offline   Reply With Quote
Improve Grid Quality with Autogrid Polito Fidelity CFD 0 October 7, 2013 05:46
