September 9, 2014, 23:40 |
Multigrid convergence problem
Rep Power: 12 |
Hi guys,
Recently I am computing a centrifigual conpressor stage connected with a volute using NUMECA. To make it converge, I decrease CFL to 2 and use the converged result on the coarse grid as the initial condition. Though the computation converges well on the second layer coarse grid (global tolerance reaches 10-6), on the fine grid it blows up and negative pressure and density turn up after several iterations. In terms of boundary condition, it is the same as previous stage calculation (without volute) which converges well (In: Velocity direction, out: mass flow). I also check the grid quality and no huge mistake appears. Note that I uses FNMB to connect the volute and the stage and the first block which contains negative pressure grid is just adjacent to this face. If anyone has faced the same problem, please help. THX. |
September 15, 2014, 12:59 |
Hamid Zoka
Rep Power: 19 |
which turbulence model do you use?
Fine Turbo has some difficulties with convergence In case of sophisticated models like SST-K omega. Try Spalart-Allmaras or Bladwin-Lomax models. Does it help? |
September 22, 2014, 03:49 |
Colinda
Rep Power: 14 |
Are you using FINE/Turbo solver or FINE/Open solver?
Such case should easily run with SST-K-omega model. It may help to see a picture of the flow field in a cut through the wheel/volute combination at the rotor-stator interface showing the direction of the velocity through the Rotor-stator interface. |
November 19, 2014, 01:42 |
#4 | |
Rep Power: 12 |
THX. |
November 19, 2014, 01:43 |
#5 | |
Rep Power: 12 |
Thanks anyway. |
coarse grid, numeca, volute |
a problem with convergence in buoyantSimpleFoam | skuznet | OpenFOAM Running, Solving & CFD | 6 | November 15, 2017 13:12 |
Convergence Problem in Axisymmetric Periodic Flow | atheresia | FLUENT | 3 | February 10, 2014 04:00 |
Submerged fin, Convergence problem | supermouniette | FLUENT | 10 | July 6, 2009 11:47 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 02:17 |
CONVERGENCE PROBLEM - oil boiler | MM | FLUENT | 1 | February 15, 2007 06:24 |
