December 19, 2012, 05:59 |
Problem in Task Manager
Vladimir
Rep Power: 14 |
Hi all!
When I try to run the case in task manager as serial computation it crashes: ... RALLOX: WORK IS OUT OF BOUNDS DATA TREE END: 136783192 STACK: 136773021 INCREASE MXRVAR EURANUS KILLED BY PROCESS ... When I try to run this case in task manager as parallel computation it crashes: ... Relative amplitude of R-coord. correction : 2.4382947E-03 Relative amplitude of R-coord. correction : 2.4382947E-03 Relative amplitude of Z-coord. correction : 3.2057901E-03 Relative amplitude of Z-coord. correction : 3.2057901E-03 EURANUS KILLED BY PROCESS 2 EURANUS KILLED BY PROCESS 1 FLOW SOLVER CRASHED ... But when I run this case from the FINE/Turbo it works. Does anybody know what is the problem or where, at least, I can find MXRVAR? |
June 1, 2017, 10:19 |
MXRVAR may be Max Real Variables.
#2 | |
Xiaolong Tang
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 05:43 |
Problem in implementing cht | tilek | CFX | 3 | May 8, 2011 09:39 |
Incoherent problem table in hollow-fiber spinning | Gianni | FLUENT | 0 | April 5, 2008 11:33 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 07:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 20:13 |
