Home > Forums > Visualization & Post-Processing Software > EnSight
Ensight clipping plane
Like Tree1Likes
  • 1 Post By Marina G
Old   July 20, 2017, 15:18
Default Ensight clipping plane
FriedTM is on a distinguished road
I am pretty new here but I am having an issue with a clipping plane which only shows the outside barrier as seen below.
here are my current settings
I really need a cross section am I doing something wrong?
FriedTM is offline   Reply With Quote
Old   July 20, 2017, 16:06
Marina G's Avatar
Marina Galvagni
Marina G is on a distinguished road
Hi Fried,
There are two possibilities:
1. you are selecting the wrong part when creating the clip. In order to get a section of the Fluid, you need to have selected the fluid domain when creating the clip. In CONVERGE, the fluid domain is usually part #2, called CONVERGE Cell Data. Make sure this is the part that you have selected in the part list (top-left), when you click on the "create" button of the clip editor
2. The clip has been created correctly, but it is only showing the borders. Select the clip part in the part list, then click on the Part element settings icon (top-right, the icon that looks like a blue/green cube). Make sure this is set to 3D *, 2D full (any of the first three options). If this is set to Border or Feature angle, it will show only the border of the part.
Hope this helps. Please let me know if none of this solves your problem.
Best Regards,
Marina Galvagni
CEI Software Support Engineer
FriedTM likes this.
Marina G is offline   Reply With Quote
Old   July 20, 2017, 16:48
Yes the problem was that I was selecting both the cell data and the outer wall by mistake. Thank you for your help and time!
clip plane, ensight
Ensight cut plane visualization HHOS EnSight 5 May 19, 2017 15:34
Grid cut plane with 3D elements in Ensight SH_P EnSight 5 September 30, 2015 18:34
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 13:43
Clipping Plane Alshroof CFX 2 July 27, 2007 18:02
