Home > Forums > Visualization & Post-Processing Software > EnSight
How to successfully export jpeg image with User defined Windows Size in Batch mode
Like Tree4Likes
  • 2 Post By potofus
  • 2 Post By Marina G
Old   April 25, 2016, 06:16
Default How to successfully export jpeg image with User defined Windows Size in Batch mode
jan bono
potofus is on a distinguished road
Hi everyone,
As stated in the title, i would like to run ensight in batch mode. I have a command file ( .enc ) that i can run without any problem. In the end it gives me an screenshot of the work it did : multiple viewport, labels, legends, etc...
The command is the following :
file: image_format jpg
file: image_format_options Quality 100
anim_recorders: render_offscreen ON
file: image_numpasses 8
file: image_stereo current
file: image_screen_tiling 1 1
file: image_window_xy 2000 2000
file: save_image
Problem is, when i do it WITH the interface and export manually my image, it works : I have a 2000X2000 image of my work. If i do it in batch mode, it doesn't work => The output image is "forced" to be in 1280X720, so the image is compressed , and some legends and labels overlap.
Is there a way to stop it from re-dimension the exported image ?
thank you for your answer
EDIT
________________
I am using EnSight standard 10.0.3(a)
pathofEnSightexe -X -batch -p nameofthefile.enc
I missed in my code the line :
file: image_window_size user_defined
This line solved my problem so in the end i have :
file: save_image
This is the line that tells EnSight to not use the default windows size, but to actually read the file: image_window_xy line. Please add it before the
"file: image_window_xy ...."
line
Indeed, i may have forgotten it while taking the command code.... ups.
potofus is offline   Reply With Quote
Old   April 25, 2016, 12:50
Marina G's Avatar
Marina Galvagni
Marina G is on a distinguished road
Hi Jan,
A few comments:
1. It'd be useful to know what exact version of EnSight you are using (10.X.X(x)). Indeed the command language to save images have slightly changed between versions
2. It'd be useful to know also what commands you are using when running EnSight in batch. Indeed there are some flags that can be used that will set the size of the viewport (and therefore of the exported images), that take priority over the commands in an .enc file.
3. The command language you are using seems to be missing the line
line
4. I am not sure where the command "flag__link" comes from? This doesn't seem to be one of the default Ensight command.
Hope this helps. Please let me know your comments to each point if you still need help.
Best Regards,
Marina Galvagni
CEI Software Support Engineer
Marina G is offline   Reply With Quote
Old   April 26, 2016, 04:25
jan bono
Tank you Marina for your quick answer, i realized my post was indeed not really complete and i will update it.
I am using the command
line
It is a personnal addition that is replaced when executed by the command that saves the image in a precise path :
file: image_file nameofthefile
In the end, it worked ! I don't know how but , in the provess of copying, i must have forgot the command :
Thank you very much for your help
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 05:26
CFX 5.5 Roued CFX 1 October 2, 2001 17:49
