April 8, 2016, 11:29 |
Unwrap cylinder into a 2D plane
Paul
Rep Power: 14 |
I need to show a contour of a value over the cylinder surface in a 2D plane representation (see the image below). I have found that there is an option in EnSight which perform the unwrapping of revolution surface to 2D tools but I cannot understand how to use it. Can someone help me and show an example of such operation? Capture.PNG Thank you in advance, Delcraft |
April 11, 2016, 11:50 |
Marina Galvagni
Rep Power: 12 |
Delcraft,
You can download from here: https://www.transferbigfiles.com/a96...sVF0G7Pphe8eg2 a screenshot movie with audio that shows an example of using developed surfaces. You can find all the details on this feature in the Help -> User Manual -> ch. 5.1.5 Let us know if you have questions. Best Regards, Marina Galvagni CEI Software Support Engineer |
June 1, 2016, 06:13 |
Paul
Rep Power: 14 |
Marina,
Sorry for the late reply. It works perfectly, thank you so much for your help! Best Regards, Delcraft |
April 17, 2021, 11:13 |
west bengal
can you please resend the link as it is no more active
April 10, 2023, 05:01 |
Alec B
Can you please resend the link ? Would be very helpful!
developed surface, unwrapping |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 03:09 |
Unwrap the cylindrical surface to a plane | CFDturbomachinery | CFX | 3 | December 31, 2014 18:06 |
how to make circular cylinder plane?? | teguhtf | FLUENT | 0 | May 27, 2012 05:34 |
[blockMesh] Specifying boundary faces failes in blockMesh | blaise | OpenFOAM Meshing & Mesh Conversion | 0 | May 10, 2010 04:56 |
expanding cylinder surface plots to a plane | klarke | CFX | 3 | October 7, 2006 20:43 |
