September 16, 2015, 05:26 |
Avoid ensight file corruption
Rep Power: 13 |
Hello;
I am having troubles exporting a transient case into ensight. When loading a variable, I always get an error such as "ERROR: Unidentifiable line read in variable file: filename.scl2" This error was discussed with no nice outcome in the following threat: http://www.cfd-online.com/Forums/ens...ing-error.html So, my question is, what is the best way to avoid the file corruption while exporting a transient calculation? I understand that the ensight files are often open whenever Fluent requires to save the next time step, so I guess the corruption might come when starting and stopping the simulation to check it, or, of course, if I open the ensight file before it is finished (the ensight files are far too easily corruptible, I'd say). Is the option "save every time step in a separate file" safer? I am asking just to know how people deal with this problems... Thanks |
September 16, 2015, 14:41 |
Marina Galvagni
Rep Power: 12 |
When exporting from Fluent in Case Gold format, as a general rule the "save every timestep in a separate file" is probably safer. It may avoid or reduce the risk of the data getting corrupt. Given that the error appears to be in how Fluent exports into Case Gold format, you probably want to contact the Fluent support directly and have them look at the issue / fix this problem. As a work-around, you can try to use the .cas and .dat files to read the transient solution - EnSight indeed has a direct Fluent reader. Typically, the EnSight Case Gold format gives you a better performance as it's designed to be optimized with EnSight, but in this case using the Fluent format can be a work-around. Hope this helps. Bests, Marina Galvagni CEI Software Support Engineer |
corrupted, ensight, transient |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 04:30 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 02:22 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 04:23 |
[swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 14:59 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 02:24 |
