June 22, 2015, 17:12 |
How to Calculate Mass Flow Through Boundary
Venkatesh V
Rep Power: 17 |
I have transient data loaded into EnSight. How to I calculate mass flow through inlet boundary and plot it in graph.
Also I would like to animate the graph by highlighting mass flow at current time. |
June 23, 2015, 15:40 |
Marina Galvagni
Rep Power: 12 |
Select your inlet boundary part in the part list. Open the calculator tool (icon at the top-left). If you have the density field, then calculate Momentum = velocity*density. Then, calculate the Mass flow by using the "Flow" function (that calculates the Surface integral of the input vector field) setting Momentum as the vector field. Give a look at this link for more details on the Flow calculations (in particular, point b) focuses on Mass flow calculations): https://support.ceisoftware.com/hc/e...-using-EnSight You should now have created a new variables that is your Mass flow. It will appear in the variable list (bottom-left) under Constants - in EnSight, "constants" means constant in space, not in time. Right-click on it and select "Plot vs. time". The plot of the flow vs. time will appear on the viewport. If you change timestep, the vertical line corresponding to the time at which you are will update automatically. Would you have more questions or problems, let us know. Best Regards, Marina Galvagni CEI Software Engineer Support |
March 15, 2018, 10:16 |
Hiren Tala
Rep Power: 10 |
I have to calculate massflow rate of Co2 out of mixture of 5 gases available in the pipe at the one cross sectional surface. how can i show and calculate perticular for one gas only? what you mensioned above is for Total massflowrate.
Any reply will be appreciable. thanks in advance |
March 15, 2018, 10:47 |
Marina Galvagni
Rep Power: 12 |
I assume you have quantities such as: density of the gas (scalar field), species concentration for the gas component you're interested in (scalar field), gas velocity (vector field). And, you have a 2D part which is the cross section where you want to calculate the mass flow. In this case, first create a new variable: species_momentum = species concentration * density * velocity This will be a vector field that is the momentum for only that species, not the whole gas. Now calculate the Flow and FlowRate using this species_momentum instead of the velocity. Give a look at https://support.ceisoftware.com/hc/e...-using-EnSight for more details on the flow calculations in EnSight. Best Regards, Marina Galvagni CEI Software Support Engineer |
March 16, 2018, 06:49 |
Hiren Tala
Rep Power: 10 |
thank you so much
i got it |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 06:37 |
Modeling interface of fluid and porous, not with default setting | ftab | CFX | 27 | May 20, 2014 07:58 |
why my momentum and mass not convergence | wwwuxing | CFX | 3 | May 18, 2012 08:49 |
