April 13, 2015, 18:56 |
Calculating the wetted perimeter
Soroush
Rep Power: 16 |
How can I calculate the length of curves which bound a clip plane? Apparently, there is no built-in function for that. I figured that if I can extract the curve, I can use the IntegralLine function, but I don't know how to extract it! Cheers, Soroush |
April 14, 2015, 15:05 |
Marina Galvagni
Rep Power: 12 |
Hi Soroush,
You can extract the border of the clip as a new 1D part, and then use the Calculator function "Length", that returns the sum of all the lengths of 1D elements. To extract the border of the clip, do the following. Change the representation of the clip part to be "Border" (select the part in the part list, then use the Part element settings icon at the top-right). Then, do Edit -> Parts -> Extract. This will create a new part that is only the current representation of the parent part (the clip). So, it will be composed of only 1D elements. Now you can apply Length to this extracted part. Let me know if this is not what you were looking for, or if you have more questions. Best Regards, Marina Galvagni CEI Software Support Engineer |
Questions on dynamicTopoFvMesh | danvica | OpenFOAM Running, Solving & CFD | 80 | April 16, 2019 17:58 |
DPMFoam - Serious Error --particle-laden flow in simple geometric config | benz25 | OpenFOAM Running, Solving & CFD | 27 | December 19, 2017 21:47 |
''unknown radialModelType type Gidaspow'' PROBLEM WITH THE BED TUTORIAL | AndoniBM | OpenFOAM Running, Solving & CFD | 2 | March 25, 2015 19:44 |
Problems in calculating the fluid traction on the current structure frame in 3D models | fw407 | OpenFOAM Running, Solving & CFD | 0 | August 6, 2008 13:04 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 18:27 |
