Nusselt Number - Heat Transfer over a rotating cylinder
Like Tree1Likes
  • 1 Post By evcelica
Old   March 6, 2012, 20:53
Smile Nusselt Number - Heat Transfer over a rotating cylinder
Leandro
leomec88 is on a distinguished road
Hello guys,
I'm making a CFX simulating that consists on a air flow over a heated rotating cylinder. I would like to know how to obtain the Nusselt Number and also the averagen Nu for this situation over the cylinder. I know I have the wall heat transfer transfer coefficient but I also need to know how to creat a expression for Nu and how to create a graphic for those values of Nu. I want to keep my x axis from 0 to 2 π or 0 to 360º. Thanks you all!
leomec88 is offline   Reply With Quote
Old   March 6, 2012, 23:13
Erik
evcelica is on a distinguished road
You can do this by "create new expression" and insert your formula for Nusselt. remember if you use the wall heat tranfer coefficient it will default to using the adjacent temperature not your bulk temperature.
After you have made this expression you can also create another expression for the average Nusselt: areaAve(Nusselt)@cylinder.
To create a graphic, you define a new variable that references your Nusselt expression, and you can use this variable in a contour.
evcelica is offline   Reply With Quote
Old   March 7, 2012, 13:33
Leandro
thanks erik! But, how can I set the bulk temperature??
Old   March 7, 2012, 18:09
Erik
I think there is an expert parameter "tBulk for HTC" which you can set to whatever you wish.
leomec88 likes this.
Old   December 8, 2015, 14:17
Default nusselt expression
mehran
mehyan is on a distinguished road
what is the expression of nusselt number for double pipe heat exchanger?
mehyan is offline   Reply With Quote
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 10:01
How can I increase Heat Transfer at Domain Interf? B.Simon CFX 3 October 28, 2008 19:53
CFX Heat Transfer RJamison CFX 0 July 24, 2008 13:11
Heat Transfer from a cylinder in cross-flow Mat W FLUENT 8 October 4, 2007 18:19
