CFX Spalart Allmaras turbulence models
Like Tree1Likes
  • 1 Post By Far
Old   November 10, 2011, 07:47
Default CFX Spalart Allmaras turbulence models
LL
aweizazuji is on a distinguished road
I am using CFX13, But i cannot find Spalart Allmaras turbulence models. When i edited the ccl in the Command Editor, changing the TURBULENCE MODEL option to Spalart Allmaras(I do not know if this is right), it showed
"The parameter "Option" in "/FLOW:Flow Analysis 1/DOMAINefault Domain/FLUID MODELS/TURBULENCE MODEL" has the value "Spalart Allmaras". This does not match any of the allowed values: "Laminar, k epsilon, k epsilon EARSM, SST, ...".
I am not sure if i am using the so called Beta version. How to add Spalart Allmaras turbulence models in CFX.Thanks!!!!!
aweizazuji is offline   Reply With Quote
Old   November 10, 2011, 08:12
TWA
TWA is on a distinguished road
(I assume) It's the one called Eddy Viscosity Transport Equation. Check the help files to confirm.
TWA is offline   Reply With Quote
Old   November 10, 2011, 08:39
LL
thanks for your reply,I will have a try.
Old   November 10, 2011, 09:17
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
It shall be shown in in CFX Pre once you enable the beta features.
check this out http://www.cfd-online.com/Forums/cfx...ras-model.html
mahdi6788 likes this.
Far is offline   Reply With Quote
Old   November 10, 2011, 09:39
LL
Thanks ver much. How to enable the beta features?
Old   November 10, 2011, 09:52
Far
Sijal
Figures are attached at the very very last post in this thread http://www.cfd-online.com/Forums/cfx...chinery-3.html
Old   November 10, 2011, 09:53
LL
I did the following steps to enable the beta features.
"start CFX-Pre and select Edit > Options. When the Options dialog appears, select CFX-Pre and check Enable Beta Features. Click OK to save the change. You will now be able to access the “beta visible” features listed below. "
Now I can still not be able to see the spalart-allmaras model.
Thanks!!!
Old   November 10, 2011, 09:57
Far
Sijal
you should be
Old   September 24, 2013, 11:02
Ghaith
ghtunmun is on a distinguished road
Hi everybody,
I'm trying to use the SA-model with cfx 14.5 but I don't know why the wall scale equation is resolved with this model. Am I making a mistake by defining my case or is it normal?
ghtunmun is offline   Reply With Quote
Old   September 24, 2013, 11:53
siw
Stuart
siw will become famous soon enough
Neither the CFX Help or the Training Material from the ANSYS Customer Portal includes anything about the Spalart-Allmaras model since it remains a beta feature but in the CFX (14.5) Modeling Guide section 4.2 it says All turbulence models in CFX are suitable for a wall function method.
siw is offline   Reply With Quote
Turbulence postprocessing Mohsin FLUENT 2 October 3, 2016 15:18
boundaryFoam, axisymmetry and turbulence models thomas_toulorge OpenFOAM Running, Solving & CFD 0 May 12, 2011 14:05
Numerical integration of Spalart Allmaras turbulence model RenardP Main CFD Forum 0 June 11, 2009 15:53
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 10:52
Spalart Allmaras Turbulence model - Need article! CFD Student Main CFD Forum 0 December 27, 2004 05:28
