Particle deposition on circular cylinder in turbulent flow
Like Tree1Likes
  • 1 Post By Julian K.
Old   October 3, 2011, 18:02
Default Particle deposition on circular cylinder in turbulent flow
Julian Krick
Julian K. is on a distinguished road
Hi!
I would like to simulate the deposition of spherical particles (dia: 30 microns, density: 600 kg/m^3) on a spherical, oscillating cylinder with ANSYS CFX 13.0. The flow is turbulent (Re = 6000, air at T=20°C). -> you'll find all parameters in the attached pdf
I'd like to use URANS turbulence model, which calculates the mean flow field. Thus, the eddies are not resolved. However, for the particle deposition, these eddies are important, since they may transport particles to the surface of the cylinder. Hence, a LES would be more appropriate. However, this requires more computational resources, which I don't have. So, my question is: is it possible to simulate my scenario using URANS and get reasonable results for the particle flow? How would I do this using CFX 13?
Furthermore, I am searching for studies on "particle-turbulence interation", "particle deposition form turbulent flow" and "particle deposition on bluff bodies + turbulent flow". Can you recommend any papers or books, which deal with this topic?
Cheers,
Julian
engineer.iman likes this.
grid generation: ICEM CFD 13.0
solver: CFX 13.0
Julian K. is offline   Reply With Quote
Old   October 3, 2011, 18:51
Then maybe you should use the turbulence dispersion model. Then you can still use RANS but include a random dispersion due to the larger turbulent eddies.
dpm, les, particle, turbulence, urans
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 14:06
2D flow around a circular cylinder Oye FLUENT 0 July 2, 2011 00:59
Which Solver/Model to use for flow over Circular Cylinder ? Re [1 , 10^6] WolfgangS. OpenFOAM Running, Solving & CFD 1 December 6, 2010 03:48
Flow around circular cylinder arm Main CFD Forum 0 June 20, 2006 06:12
flow around a circular cylinder Hanson He Main CFD Forum 0 November 17, 1998 11:39
