September 3, 2011, 11:50 |
Error:: Floating point overflow
Arun raj.S
Rep Power: 16 |
My Problem is i have to find the exit velocity components of a distortion screen and have to give that as a inlet boundary condition for a complete rotor domain.. I have created the mesh for 90 degree distortion screen through Icem cfd and I have imported that in Ansys cfx....Earlier it has shown i m having isolated volumes ..But i m sure there are no isolated volumes ..So i have set the expert parameter to uncheck the isolated volumes ... After that it has shown that integer and real memory are low..so i have increased the stack memory size..Now finally it is showing "floating point overflow error "...( ONly 10 iterations are going after that solver gets stopped) type::steady state simulation Inlet boundary condition :: Cartesian velocity components u= 100 m/s v=0 w=0 Outlet boundary condition:: mass flow rate mass flow rate= 2 kg/s Remaining faces of the domains :: I have considered it as opening Opening boundary condition values:: Relative pressure = 1010325 pa Temperature :: 300k FOR SCREEN :: I HAVE CONSIDERED IT AS A WALL For the screen which i have kept inside the center part of the domain, i HAVE CONSIDERED THE SCREEN AS A WALL Turbulence model:: Shear transport(SST) Heat transfer model:: Total energy Solver settings:: Advection scheme:: High resolution Auto time scale:: conservative:: Time scale=0.75 I am not understanding whether i m doing any mistake in Boundary conditions..So plz help me in sorting this problem I m attaching a picture of model for reference... Your help will be highly appreciated |
September 3, 2011, 21:19 |
Rep Power: 144 |
I would keep the check for isolated volumes. Your logic for removing it seems bizarre.
Solver overflow means you need to improve the numerical stability of the solution. Smaller time steps, better mesh, double precision are the main suggestions. I should write an FAQ on this, getting a bit sick of writing this explanation. |
September 4, 2011, 04:20 |
Arun raj.S
Rep Power: 16 |
Hii Glenn Horrocks,
I am sure there is no isolated volumes thats y I have unckeck it..May be I have poor mesh quality..The problem is I have mesh this geometry in Icem CFD...But can u check and say whether there is any thing wrong with the boundary conditions which i have given? |
September 4, 2011, 07:50 |
Antoni Alexander
Rep Power: 17 |
September 4, 2011, 12:22 |
Arun raj.S
Rep Power: 16 |
Hi zkdkeen,
Sry sry its 101325 pa only..Mistakenly typed...But I m thinking now since it is relative pressure I have to give as 0 pa rite... |
September 4, 2011, 21:06 |
Rep Power: 144 |
You have a specified velocity inlet and a mass flow outlet. This is poorly posed boundary conditions - read the documentation about defining boundary conditions. You should make one or other a pressure boundary.
February 8, 2012, 02:59 |
Floating error
Rep Power: 14 |
Hello.
I am getting floating error:invalid number. I am working on train moving in tunnel. Can any body help me. My email is sheikhnasir39@gmail.com thanks |
February 8, 2012, 05:58 |
Rep Power: 144 |
I think there are four active threads which are asking about floating point errors. This is getting a little tedious.....
Do a search on the forum and find threads talking about this. It has been asked thousands of times. UPDATE: I have deleted the many duplicate posts you put up on exactly the same topic. Please do not put duplicate posts up, I will just delete them. |
block-structured mesh for t-junction | Robert@cfd | ANSYS Meshing & Geometry | 20 | November 11, 2011 05:59 |
Floating point exception: Overflow? | mike | CFX | 4 | December 15, 2009 18:30 |
Error #001100279 (floating point overflow) | Reza | CFX | 4 | September 24, 2009 16:15 |
[Gmsh] Gmsh and samplesurface | touf | OpenFOAM Meshing & Mesh Conversion | 2 | December 10, 2007 03:27 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
