post process in CFX
Like Tree3Likes
  • 2 Post By Lance
  • 1 Post By Dimeflow
Old   August 10, 2011, 14:47
Default post process in CFX
Hamed
safikhani_hamed is on a distinguished road
Dear friends,
Is it possible to open multiple windows in CFX-post simultaneously and define a figure like attached file ?
safikhani_hamed is offline   Reply With Quote
Old   August 10, 2011, 19:09
Yes. CFD-Post can handle multiple views. I don't think it likes three across like that, it prefers 2x2 grid but hopefully that's close enough.
Old   August 10, 2011, 19:34
mjgraf is on a distinguished road
you can create your plots/vectors at the planes you desire then Apply a Transformation in the View tab for the vector plot. This will just shift the plot in space, align as needed.
mjgraf is offline   Reply With Quote
Old   August 10, 2011, 22:03
Hamed
In fact I mean multiple runs and not multiple sections of one file for example we want to compare the effect of Re number and we have obtained the solution for Re=1, 100, 1000 and we want to compare the a contour for these Re numbers in one view.
Old   August 11, 2011, 03:42
monkey1 is on a distinguished road
If I understood you well you have 3 .res files which you want to compare right?
If it is so you can Open Post and then load all three files by checking the option "Keep current cases loaded" in the load results files window.
As default the option "Open in new view" is checked, so that you will obtain a view for each case in one window.
The only problem remaining is as glenn already mentionned, that CFX Post only creates 2x2 grids of views and does not offer the option of having an unpair number of views of the same size.
For each view you will be able to select timesteps (in case of transient runs) or set separate visualisation options. Or if you want to have all views with the same options there is a button on the viewing tools toolbar (where u have all the tools for zooming, rotating etc.) in CFX Post called "synchronize visibility" wich will let all stuff like vectors, contour plots etc. appaer in all views simultaniously. With "synchronize camera" You will be able to have the same angle of view and zoomfactor in all views.
Is this what you were asking?
monkey1 is offline   Reply With Quote
Old   August 11, 2011, 04:58
Hamed
Extreme thanks, yes I think you solved my problem, I tell you later after I test that.
sincerely
Old   August 11, 2011, 05:14
Hamed
I checked, it does work and solve my problem, but is there any way to overcome 2*2 grid problem ?
Old   August 11, 2011, 05:18
Not as far as I know.
The Only "Workaround" would be to take the view with one large view in the upper half and two small in the lower half or vertically oriented left and right insteadt of upper and lower.
This would be usefull if you could say you have one "main case" which I would display in the large view then and two Variations of this case which I would display in the smaller views.
Glad I could help you!
Old   August 11, 2011, 05:46
Hamed
I think another way for post process more than 4 windows is to export results with CGNS format to tecplot software.
Old   August 11, 2011, 07:34
Lance
Lance is on a distinguished road
Load one file and open the "Load results" again. Check "keep current cases loaded" and uncheck "open in new view" before you load the second file. Then just apply translation on one of the cases. Now you have two results in one view. Repeat for more files.
Lance is offline   Reply With Quote
Old   August 11, 2011, 07:40
Hi Lance....
What do you mean with "apply translation"???
Old   August 11, 2011, 07:45
Lance
Originally Posted by monkey1 View Post
Hi Lance....
If you load two cases in the same view you will e.g. have one called "name"_001 and one "name_002". Double click on "name_002" and check Apply Translation and move the second results file a bit so they dont overlap.
monkey1 and agustinnie like this.
Old   August 11, 2011, 08:07
Very Cool thing!
Thx for the Info a lot!
Old   August 12, 2011, 04:45
Dimeflow is on a distinguished road
cheers. im an idiot, ive used CFX for years and never done this.
monkey1 likes this.
Dimeflow is offline   Reply With Quote
CFX Post export problem jeff_F CFX 0 August 17, 2009 22:25
chart for transiente simulation - CFX Post rogbrito CFX 0 June 22, 2009 13:12
CFX 11, post Anant CFX 1 June 24, 2008 12:03
ANSYS CFX POST State file Mechstud CFX 1 June 22, 2007 15:59
Proper output of angle of attack in CFX post Kevin CFX 3 October 18, 2006 13:18
