July 18, 2011, 06:01 |
Problem with interface
Roland Rakos
Rep Power: 17 |
Hello CFX Users,
The solver has given the next error: ********* WARNING ********* No control surfaces have been found for the domain interface Domain Interface 2 If you expect this to occur, please set the expert parameter 'ggi permit no intersection=t' to work around this message. I would like to realize a special moving mesh where the interfaces are not in contact in the beginning of the transient process I have seen this error previously and the 'ggi permit no intersection=t' expert parameter was good solution for this problem in every case, but now this expert parameter can not be found in CFX 12.1. Is it possible? Thanks Roland |
July 18, 2011, 07:44 |
Rep Power: 144 |
Do you get the error message in V12 or later?
July 18, 2011, 08:24 |
Roland Rakos
Rep Power: 17 |
Error can be found in V12.1
Meanwhile I have found this "permit no intersection" setting but in V 12.1 this option can be found under solver control / advanced options / intersection control |
August 16, 2013, 05:09 |
Drillerman
Rep Power: 13 |
Heloo I have the same problem, my question but, how can I set the expert parameter
'ggi permit no intersection=t'!! is there any where in CFX tools something so, if yes, then where!! |
August 16, 2013, 08:04 |
Rep Power: 144 |
In CFX-Pre I think it is under options/expert parameters pull down menu.
August 16, 2013, 09:01 |
Drillerman
Rep Power: 13 |
March 1, 2018, 09:24 |
urosgrivc
Rep Power: 12 |
maybe it helps:
It is probably not an expert parameter it is a CCL parameter Permit no intersection is found under conection tab -> mesh connection -> intersection control -> permit no intersection |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
problem in mesh interface | shiyan189 | FLUENT | 0 | April 23, 2010 14:53 |
interface boundary problem | Rashad | FLUENT | 0 | April 23, 2007 06:27 |
Interface problem | sai | FLUENT | 1 | January 19, 2007 03:26 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 21:09 |
