Temperature profile of a cylindrical wall in CFX |
July 13, 2011, 10:29 |
Hamed
Rep Power: 17 |
Dear friends,
In fact I want to use a special temperature profile at a cylindrical wall in CFX (as shown in attached file). Can any body help me please to do that ? in there any tutorial or document ? Sincerely |
July 13, 2011, 12:32 |
Rep Power: 17 |
Hi
It is easy to define the temperature variation vs a distance by using a function in CFX-Pre. |
July 13, 2011, 13:08 |
Temperature Profile
Hamed
Rep Power: 17 |
Dear Abou Ali,
Thank you very much, but my problem is that the wall is rounded and not straight, have you any document to send me please ? |
July 13, 2011, 13:32 |
Rep Power: 17 |
If you need documentation about CFX-Pre Function you can find it in the CFX Help. You can see also tutorial 19 Air Conditioning Simulation (CFX 13). |
July 15, 2011, 05:58 |
CFX Tutorial
Alireza Safikhani
Rep Power: 16 |
There are some exampls in the cfX tutorial about functions. you can use them.
July 20, 2011, 02:04 |
Hamed
Rep Power: 17 |
Dear Abou Ali
In fact I read the mentioned tutorial, but in that example show using the functions in CFX but has not explain how can write a function. Do you know how can I write a function to show for example a linear temperature profile ? Sincerely |
July 21, 2011, 09:20 |
Rep Power: 17 |
This is the procedure to create and use a function in CFX Pre. The function is T=f(x) and the known data are: T1 at x1 T2 at x2 T3 at x3 The units of T and x are K and m respectively Procedure 1- From the main menu, select Insert > Expressions, Functions and Variables > User Function. 2- In the New Function dialog box, type Tempx. 3- Click OK. The details view for the Tempx function is displayed. 4- In the Argument Units box type [m] 5- In the Result Units box type [K] 6- Set Option to One Dimensional 7- In the Coordinate box type x1 8- In the Value box type T1 9- Click Add 10- Repeat steps 7 to 9 to add x2,T2 and x3,T3. 11-Click OK ***************** From the main menu, select Insert > Expressions, Functions and Variables > Expression. 2. In the New Expression dialog box, type Tx. 3. Click OK. The details view for the Tupper equation is displayed. 4. Under Definition, type Tempx(x) . 5. Click Apply to create the expression. The expression is added to the list of existing expressions. |
Conjugate heat transfer: coupled wall temperature | Sarah | FLUENT | 7 | August 12, 2013 23:36 |
Wall function formulation in CFX and Fluent | gravis | ANSYS | 0 | May 4, 2010 12:03 |
constant wall temperature | abir | Fluent UDF and Scheme Programming | 0 | April 27, 2010 13:08 |
How to input the wall temperature b.c.? | Jimmy | Siemens | 16 | March 7, 2008 15:11 |
temperature profile on boundary | sivakumar | FLUENT | 5 | November 24, 2002 01:58 |
