June 19, 2011, 21:48 |
calculating n plotting moments coefficients
kurniawan
dear all....
i want to ask something...how to obtain moments coefficient on the CFD-Post? which function can i use?i've tried using the "torque" function but the results were not as i expected. i guess it should use the "torque" function, but the choice of the axis there is only X, Y and Z.there is no choiceof the Y-axis at 1/4 chord. what's the solution? do i have to start again from ICEM to put the center of axis at 1/4 chord or wing? thanks before |
June 20, 2011, 02:37 |
Hi
Dynampally Pavitran
Rep Power: 16 |
June 20, 2011, 10:59 |
#3 | |
kurniawan
i see...i will try your suggestion. thanks a lot |
moment |
[CFD-Post] Calculating aircraft moments | siw | CFX | 0 | February 28, 2011 07:32 |
Problems in calculating the fluid traction on the current structure frame in 3D models | fw407 | OpenFOAM Running, Solving & CFD | 0 | August 6, 2008 13:04 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 18:27 |
Density for calculating Force Coefficients | ste_lakey | CFX | 2 | September 19, 2005 05:35 |
Calculating Coefficients | shabah | CFX | 2 | June 19, 2001 00:59 |
