June 3, 2011, 17:58 |
how to show the particle deposition spots?
Rep Power: 17 |
I am doing a particle tracking CFD simulation. How can I set up in CFX-post to only show the particle symbols of their final locations (either deposited or flow out of the domain)? I tried everything, adjusting max time, min time, interval etc... Thanks a lot! |
June 17, 2011, 11:06 |
Rep Power: 18 |
What do you mean by particle symbols?
May 23, 2013, 20:58 |
Liliana de Luca Xavier Augusto
Rep Power: 13 |
Hello, I have tha same problem!
How can I show only the particles trapped on the wall? And how can I calculate how many particles are trapped? My simulation is in steady-state and I am using Eulerian-Lagrangian approach. |
July 23, 2015, 22:51 |
jichaoudz
Hello , i meet the same problem - trap and count particle number, Have you solve the problem, can you help me?
July 24, 2015, 10:23 |
Rep Power: 13 |
July 27, 2015, 07:18 |
Rep Power: 18 |
This is just off the top of my head...
1. To show contour plots: You need to follow the ice accretion tutorial. I.e. turn on accretion for paticles. This will allow you to show particles as contour plots, either on walls or on planes. 2.To count the exact number on walls you need to do go to: Results>sample>DPM>select walls. Write to file and then this will have a line count. Count the number of lines either manually, matlab or via a shell script in linux to give you the exact number of particles deposited. (This method gives particle coordinates in x,y,z so you can plot these in matlab if you want too). |
May 10, 2017, 16:21 |
#7 | |
Patrick
Rep Power: 9 |
Any help to get accretion rates using CFX and CFD-Post would be great. |
Particle transport and deposition & Drift Flux Model | Peter023 | Fluent UDF and Scheme Programming | 3 | April 21, 2021 00:50 |
Normal particle velocity in particle deposition! | Prashanth | Fluent Multiphase | 1 | May 29, 2013 23:30 |
particle deposition pattern | sarah_ron2002 | FLUENT | 3 | January 12, 2011 07:37 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 02:29 |
Particle Deposition in CFX11.0 | siavash ghassemi | CFX | 0 | January 10, 2008 10:29 |
