Error msg: In Analysis 'Flow Analysis 1': No domains have been defined.
Like Tree3Likes
  • 1 Post By spwater
  • 2 Post By monkey1
Old   May 31, 2011, 08:03
Default Error msg: In Analysis 'Flow Analysis 1': No domains have been defined.
Shui Pei
spwater is on a distinguished road
It worked in the past but one day the cfx gave me the messege:
and stops reading my mesh file.
Some one knows whats happening?
I make a sphere and a box in the workbench, and make the mesh by sizing to the box and refining to the sphere then generate the mesh and save.
when I open the setup, the error message appears.
FENG WANG likes this.
spwater is offline   Reply With Quote
Old   May 31, 2011, 09:25
Looks pretty obvious to me - no domains are defined. Go back to CFX-Pre and define a domain.
Old   May 31, 2011, 09:53
Shui Pei
The msg appears after I import the mesh, without the mesh how can I define a domain?
Old   May 31, 2011, 10:28
Christa
user_of_cfx is on a distinguished road
Import the mesh then right-click on Flow Analysis 1 and choose insert domain, give the new domain a name (preferably NOT domain 1, I usually choose the type of fluid I'm simulating, such as water) and then define BODY, or whatever name your volume has as your desired domain.
Sometimes these things may need re-defining, even though the same stuff has worked before.
If your mesh won't be imported, even though the same mesh file used to work before then I'm sorry I cannot help, but looking into the mesh file, instead of the .cfx file may have your answer. Sometimes re-doing the geometry and mesh is the tedious but fastest way round the problem.
Hope this helps.
user_of_cfx is offline   Reply With Quote
Old   July 29, 2012, 12:39
bratzinger is on a distinguished road
if u are german -> this could help:
keine umlaute(ä, ö, ü) verwenden - auch nicht im Projektnamen
bratzinger is offline   Reply With Quote
Old   July 31, 2012, 04:17
monkey1 is on a distinguished road
Addendum to what bratzinger said...not only do not use ä,ö,ü in the projectname...BUT do NOT use ANY special Signs in the WHOLE Path!
I had similar problems when I wanted to open a file located in smth. like:
C:/CFX/Projects/Gebäude/Setup/Files/Pre/
and it gave me a similar error just because I had a Folder "Gebäude" containing the folders where my files are stored. I think this is valid also for all other language specific symbols or symbols like %, & and so on....Therefore I now name my files and folders only with standard alphabet and "_" as a separator/space. Because when I use " " (blanks) as space I get problems on unix/linux machines.
heinz and johann_angel like this.
monkey1 is offline   Reply With Quote
Old   September 10, 2012, 09:08
Default long PATH
Heinz Mutzner
heinz is on a distinguished road
in MS-Windows this seems to happen too, when the path to the file is very long
heinz is offline   Reply With Quote
Old   October 29, 2020, 05:28
Unhappy In Analysis 'Flow Analysis 1': No domains have been defined.
Kourosh
Kourosh_nosrati is on a distinguished road
Hi very body
I have this problem when I was imported the mesh
Could you please guide me?
thanks
Kourosh_nosrati is offline   Reply With Quote
Old   October 29, 2020, 05:41
It means what is says, you have not defined any domains, and that is probably because you have no 3d mesh regions in your mesh. Make sure your mesh is CFX compliant, with one or more 3d regions, with each 3d region bounded by surface meshes on the outer faces.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   October 11, 2022, 23:00
Aero_Cats!
IFX21 is on a distinguished road
Try to open a new CFX Pre outside of/ without the workbench and import your mesh which was created from your workbench. I don't know what exactly happening but sometimes it works
IFX21 is offline   Reply With Quote
Preocedure for thermal flow analysis in fluent sri0114 Main CFD Forum 0 September 13, 2010 07:03
Compressible flow analysis Sonu Siemens 3 December 5, 2007 08:25
User defined function of mass flow rate Eric FLUENT 1 April 22, 2005 19:15
Coolant flow analysis - IC engine Frank FLUENT 2 May 19, 2002 16:59
Flow visualization vs. Calculated flow patterns Francisco Saldarriaga Main CFD Forum 1 August 3, 1999 00:18
