[CFD-Post] High resolution scheme blend factor |
May 24, 2011, 12:55 |
Stuart
Rep Power: 26 |
Is it possible to plot the high resolution advection scheme blend factor, beta in the equation given in the User Guide? I cannot find it in the CFD-Post Variable Selector. Thanks. |
May 24, 2011, 20:15 |
Rep Power: 144 |
Yes, they are the variables like Velocity U.beta.
May 26, 2011, 05:50 |
Stuart
Rep Power: 26 |
Thanks Glenn. Is see there's 4 variables (pressure and velocity components). Plots of them did not give me what I expected though.
Likewise, I cannot see a variable for the turbulence intensity. Does one exist? Or must I make a user defined variable? I see what's needed from http://www.cfd-online.com/Wiki/Turbulence_intensity. Thanks |
May 26, 2011, 07:38 |
Rep Power: 144 |
If you have a turbulence model with turbulence intensity you will have it. No need to define a new variable. Can't remember off the top of my head what its name is, turbulent kinetic energy or something like that I think.
May 26, 2011, 08:20 |
Stuart
Rep Power: 26 |
Thanks again, Glenn.
I used the SST model and have made a contour plot of the turbulent kinetic energy (taken from the variable selector), but I'm thinking to include or replace it with a contour plot of turbulence intensity. |
May 26, 2011, 18:23 |
Rep Power: 144 |
Oh, you mean turbulence intensity as a ratio of turbulent energy to bulk flow energy? No, this variable does not exist. It is straight forward to add it as a user variable.
how to understand high resolution scheme and high order scheme | iilw1314 | Main CFD Forum | 7 | April 12, 2022 13:29 |
High order scheme vs Specified Blend factor 1 | realanony87 | CFX | 1 | November 10, 2015 11:36 |
high resolution scheme | az_f | CFX | 0 | November 24, 2010 23:52 |
larger blend factor or high resolution ? | amine | CFX | 2 | March 4, 2008 21:28 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 06:12 |
