Calculation of Reynolds Number In CFX
Like Tree9Likes
  • 2 Post By Lance
  • 3 Post By ghorrocks
  • 1 Post By mdshirazi
  • 2 Post By ghorrocks
  • 1 Post By ghorrocks
Old   January 18, 2011, 03:38
Question Calculation of Reynolds Number In CFX
Ashkan Javadzadegan
ashtonJ is on a distinguished road
Hi all
I simulated a steady flow in a pipe. Mean velocity at inlet of pipe is 0.02 [m/s]. The pipe diameter is 20 [mm]. The following data has been taken from CFX solver output file.
Global Length = 5.4614E-02
Minimum Extent = 1.9994E-02
Maximum Extent = 5.4000E-01
Density = 1.0600E+03
Dynamic Viscosity = 3.7100E-03
Velocity = 2.0012E-02
Advection Time = 2.7290E+00
Reynolds Number = 3.1227E+02
When I calculate the Reynolds number with above information. It becomes 114 while as it shown above, CFX calculated 312 for Reynolds number. Does anybody know how CFX calculated the Reynolds Number?
regards
Ashtonj
ashtonJ is offline   Reply With Quote
Old   January 18, 2011, 03:49
Lance
Lance is on a distinguished road
CFX use Volume^(1/3) to calculate the length scale, that why you dont get the same Reynolds number.
From your data:
((0.02^2*pi/4)*(5.4e-1-2e-2))^(1/3)*1060*2e-2/3.7e-3 = 313
Ethan_Sparkle and mukhtar like this.
Lance is offline   Reply With Quote
Old   January 25, 2011, 06:12
Default mean Velocity at Inlet
rskrishna87 is on a distinguished road
In my output file the Velocity is shown to be 70 but if i caluculate it in CFD -Post as ave(Velocity)@Inlet then it is much higher than that.It is 129.Can anyone please tell me what is the problem.I want to know this to calculate Reynolds number manualy in CFD-Post.
rskrishna87 is offline   Reply With Quote
Old   January 25, 2011, 06:13
Lance
Have you tried areaAve(Velocity)@inlet ?
Old   January 25, 2011, 06:35
Unhappy
yup...Its showing 150.659 which is more higher
Old   January 25, 2011, 07:00
Does anyone know how to calculate Reynolds number manually in CFD-Post using an expression??
Old   January 25, 2011, 17:05
If you want to calculate the Reynolds number you are comparing against literature values, you need to use the same definition of Reynolds Number.
These are my guesses:
Velocity scale = areaAve(Velocity)@inlet
Length scale = the diameter of the cylinder or chord length or whatever the geometry is
density scale = areaAve(Density)@inlet
Viscosity scale = areaAve(Viscosity)@inlet
Then you can define Re number using these numbers.
nimap, bayramuks and aero_head like this.
Old   November 9, 2013, 06:50
shirazi
mdshirazi is on a distinguished road
Dear Ashton,
I am aware that it is a long time since you have posted here,but I need a help .I cannot find Reynolds number in CFX outputs in CFD post. I normally calculate Reynolds number by hand. As you have mentioned here; there is way how to get Reynolds number from cfx itself. Could you give me some information in this field?
bayramuks likes this.
mdshirazi is offline   Reply With Quote
Old   November 9, 2013, 07:21
Write a CEL expression which calculates it and send it to a monitor point. Easy.
But don't be fooled by the Reynolds Number reported in the output file.
Abhi.shek and bayramuks like this.
Old   November 9, 2013, 08:31
shirazi
Dear Glenn,
Thanks for your replay, The problem is that different part of a problem have different length scale. Are you suggesting that there is a built-in length scale function in CFX?
Old   November 10, 2013, 05:30
There is some built in functions. The turbulence transition model has some functions in the Gamma-theta model. There is the wall distance function for the SST turbulence model.
But usually you have to write your own function appropriate for your geometry.
mdshirazi likes this.
Old   July 17, 2015, 04:56
nima
nimap is on a distinguished road
What if the shape of geometry be so complicated, how can gain hydraulic diameter by CFD-post?
nimap is offline   Reply With Quote
Old   July 17, 2015, 07:32
Any CFD textbook can define you how to get the hydraulic diameter. Then it is usually straight forward to implement it in CFD-Post.
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 08:59
Reynolds Number Again Ogbeni CFX 2 June 3, 2005 00:34
Reynolds number in CFX tuks CFX 0 May 25, 2005 02:16
Low Reynolds number K-Omega modeling Athar Zaidi Main CFD Forum 0 October 31, 1999 14:59
