Error in CFX Solver
Like Tree3Likes
  • 1 Post By ghorrocks
  • 2 Post By ghorrocks
Old   November 4, 2010, 04:03
Default Error in CFX Solver
Niklas
Leuchte is on a distinguished road
starting the CFX-Solver with my project, the following Error-message appears after partitioning:
| Solver |
| An error has occurred in cfx5solve: |
| The ANSYS CFX solver exited with return code 1. No results file |
| has been created. |
End of solution stage.
| The following user files have been saved in the directory |
| \\CIFS\CLUSTER\WORK\TP98463A\KALIBRIERKANAL\CFX\Ka librierkanal_Ma- |
| 0.60_02_mflow-out0.70352_001: |
| out, mon |
STDOUT:
Could not find the file: units.cfx
job aborted:
[ranks] message
[0] application aborted
aborting MPI_COMM_WORLD, error 1, comm rank 0
[1-15] terminated
---- error analysis -----
[0] on WINHTC08
\\CIFS\CLUSTER\SOFTWARE\ANSYS_INC\V121\CFX\bin\cfx 5remote.exe aborted the job. abort code 1
STDERR:
Use of uninitialized value $cont[0] in pattern match (m//) at \\CIFS\CLUSTER\SOFTWARE\ANSYS_INC\V121\CFX\bin\/perllib/CFX5/Parallel.pm line 1880.
Feature CFX_SOLVER_BASIC_LIMIT does not exist in the ANSYSLI pool.
Feature CFX_SOLVER_BASIC_NOLIMIT does not exist in the ANSYSLI pool.
An error has occurred in cfx5remote on WINHTC08:
\\CIFS\CLUSTER\SOFTWARE\ANSYS_INC\V121\CFX\bin\win nt-amd64\double\solver-m-
smpi.exe could not be started, or exited with return code 255: .
An error has occurred in cfx5remote on WINSCC004:
An error has occurred in cfx5remote on WINHTC11:
An error has occurred in cfx5remote on WINSCC002:
An error has occurred in cfx5remote on WINSCC010:
The ANSYS CFX solver exited with return code 1. No results file has been
created.
| Indirect start method returned non-zero exit code |
| Indirect solver job failed |
Any idea what this means?
I´m using Ansys 12.1.
regards
Nick
Leuchte is offline   Reply With Quote
Old   November 4, 2010, 06:22
Does it run in serial? What about the other parallel modes?
Old   November 4, 2010, 14:31
Michael P. Owen
michael_owen is on a distinguished road
Was CFX completely installed on the individual nodes? It looks like the job can't find the units file.
michael_owen is offline   Reply With Quote
Old   November 6, 2010, 05:03
RossFS is on a distinguished road
I'd get error 255 when a simulation wouldn't run on local parallel but would run in serial mode on some 2D simulations I ran recently.
RossFS is offline   Reply With Quote
Old   November 6, 2010, 07:10
Well, you have some basic debugging to do before we can be of any assistance.
Run a simple simulation - maybe a tutorial example or the benchmark, it does not matter. Run it serial, and local parallel in various modes. Does that work? This will tell you if you have a problem with your installation. Then run your model. This will tell you if the problem is your simulation.
big-bang likes this.
Old   November 6, 2010, 07:12
BTW: The benchmark simulation can be found in <CFX ROOT>/examples/Benchmark.def. A nice simple quick demo run which is useful for debugging.
holzkiste and big-bang like this.
Error message CFX Solver Fatnes CFX 25 July 3, 2015 11:32
CFX SOLVER error !!! mehrdadeng CFX 3 November 23, 2009 17:42
mach number and CFX 11.0 solver turbinesv CFX 5 January 5, 2009 06:43
CFX Solver to run 10 files sequentially Raj CFX 8 October 29, 2008 23:20
problem in CFX solver about isolated volumes Yuan CFX 2 August 16, 2004 23:54
