August 25, 2010, 10:44 |
Modelling Turbulent Wall Functions
Victor Azevedo
Rep Power: 16 |
Hi everybody,
I'm doing a multiphase flow simulation and I have to model the wall roughness by using "turbulent wall functions". The CFX Theory Guide have an expression for this, but the big problem is in one of the variables. The turbulent wall function uses the variable u* (I think that's the friction velocity or shear velocity). This variable is available for me in the Solver, but when I run the case, in the Post this variable does not appear (CFX says that it not exist). I'm needing this variable to calculate the film thickness and other variables of my case. So, I would like to ask you how can I put this variable in my expressions. Is there any syntax? Remember that's a multiphase flow case. I attached my CCL file, so you can look. The u* is in the "Uaster" expression, and that's the origin of all my problem here. The "wall turbulent function" is in the "WTFC" expression. Thanks for your help. |
August 25, 2010, 19:03 |
Rep Power: 144 |
Your function looks OK for a single phase flow. I suspect you need to get ustar for the phase you are interested in, not sure how to do that off the top of my head.
Does the ustar function work for a single phase flow? |
January 13, 2015, 10:38 |
implemanted new wall function
adelo
Rep Power: 11 |
Hi everybody,
I'm doing a multiphase flow simulation and I want to implemanted a new wall function in CFX( So, I would like to ask who can I add this new function(U*, C,K ) Thanks for your help. |
January 13, 2015, 11:06 |
Rep Power: 33 |
You can read the following section in the documentation:
CFX-Solver Modeling Guide -> Turbulence and Near-Wall Modeling -> Modeling Flow Near the Wall -> User Defined Wall Functions |
January 13, 2015, 15:02 |
adelo
Rep Power: 11 |
thank you very much I'm going to read this document
January 13, 2015, 15:22 |
adelo
Rep Power: 11 |
I want to write new formulas for this parameter (see document). in the indicated section I understood it shows me how to change a constant
January 13, 2015, 15:49 |
Rep Power: 33 |
The software does not let the user modify the ingredients of the built-in wall function. User modifications may not be compatible to what the developers implemented; therefore, the burden is on the user to implement it all.
Use the example provided in the documentation, and see where you can introduce the modifications you need. |
January 13, 2015, 15:58 |
#9 |
adelo
Rep Power: 11 |
you speak of this exemple in (ANSYS CFX-Solver Modeling Guide
4.2.4.3. Example of User-Defined Wall Function for Heat Flux) |
January 14, 2015, 12:32 |
#10 |
Rep Power: 33 |
Yes.. You can use that example as a template to create your custom wall function
January 14, 2015, 14:53 |
#11 |
adelo
Rep Power: 11 |
thank you very much
January 14, 2015, 16:48 |
#12 |
adelo
Rep Power: 11 |
before i do the ilmplemtation of my new wall function i need just to know how can I activate the wall function in simple case two phase flow
thanks for you help |
Wall modelling and boundary conditions: why specify value for turbuelnce quantities? | djbungee | OpenFOAM Programming & Development | 2 | July 30, 2010 08:32 |
Two-Layer Models and Wall Functions | sdwijeya | Siemens | 0 | June 18, 2010 16:25 |
Are you relying on wall functions? | sek | OpenFOAM | 1 | November 8, 2009 19:27 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 06:12 |
The turbulent viscosity on the wall | maximus | Main CFD Forum | 2 | January 24, 2003 04:02 |
