FORTRAN for CFX 12
Like Tree1Likes
  • 1 Post By painterwolf
Old   June 29, 2009, 06:53
Default FORTRAN for CFX 12
Mirko
painterwolf is on a distinguished road
I need fortran for my simulation. Can anyone explain me how I can run tutoria HVAC so I can learn use it? I have problem with intallation. I would need a guide for installation of:
Intel.Visual.Fortran.Compiler.v10.1.014.EM64T
PlatformSDK_Svr2003R2
visual c++2005 express edition
I use xp 64 bit.
The command cfx5mkext don't run
painterwolf is offline   Reply With Quote
Old   June 29, 2009, 07:45
ckleanth's Avatar
George
ckleanth is on a distinguished road
make sure you actually need fortran because in v12 you have logic expressions in ccl.
As for installing it just follow the instructions in the manual (editing the corewin_express.vsprops file) as described in the cfx manual. search for Fortran, configuring on Windows. if that doesn't work contact ansys customer suport
Top 4 tips
1. Knowledge is everything and Ignorance is dangerous.
2. Understand your limitations and try to eliminate them.
3. Get yerself a bike and hoon the chuffer. You will soon learn why dogs like to hang their heads out the car window.
4. Please before asking any questions on how to run simulations in CFX, go though all the tutorials
ckleanth is offline   Reply With Quote
Old   June 29, 2009, 09:03
Smile
Jack
rogbrito is an unknown quantity at this point
Hi Sir,
for windows xp 64bits, u need only Intel Fortran v9.0/9.1, and Microsoft PLatform SDK for Windows Server 2003 SP1.
Please, don´t forget to put the CFX files in the path of Windows xp 64:
C:\Program Files\Microsoft Platform SDK\Bin\.;C:\Program Files\Microsoft Platform SDK\Bin\WinNT\.;%IFORT_COMPILER91%\IA32\Bin;%IFORT _COMPILER91%\EM64T\Bin;C:\Program Files\ANSYS Inc\v110\CFX\bin
At.Rogerio.
rogbrito is offline   Reply With Quote
Old   June 29, 2009, 12:06
Mirko
In v12, in transient simulation, can I recall, for i-step, a variable by i-1 step? I need Temperature in previous step for my equations. Can I do this?
joseduartedasilva likes this.
Old   June 29, 2009, 12:42
Jack
Using CFX-4 Routines in ANSYS CFX Release 12:
With the availability of CFX Expression Language (CEL), many of the documented userroutines presented in CFX can be set up using CEL in CFX. For details, see CFX Expression Language (CEL) in the ANSYS CFX Reference Guide.The following table lists some user routines from CFX-4, and how they can be set up in CFX.
CFX
routine and description
How to set up in CFX
USRBCS
A routine that enables the specification of real information at inlets, mass flow boundaries, pressure boundaries, walls and conducting boundaries, both at the start of a run and on each timestep.
An inlet profile using User Fortran is described in Junction Box Example 1. For details, see Junction Box Example 1: Profile Boundary Conditions. Time-varying boundary conditions can be set up using CEL, with an expression containing t.
USRBF
To enable you to specify body forces in the momentum equations.
This routine has been replaced by both CEL and loss models.
Old   June 29, 2009, 12:52
Jack
"... The direct problem considered here is concerned with
calculating the drilling tool temperatures when the applied
heat flux, heat transfer coefficient, thermal properties as
well as the initial and boundary conditions of the drill
are all known. The solution for the above 3-D heat conduction
problem in the domain
Xðx; y; zÞ with time t is solved
using CFX4.4 and its Fortran subroutine USRBCS...."
Old   June 29, 2009, 13:48
ckleanth's Avatar
George
you do realise that the user manual is copyrighted material regardles how old it is...
CFX 4? you really need to upgrade
Top 4 tips
Old   June 29, 2009, 18:58
Talking
Jack
I´m using ANSYS Release 12.0.1, build 2009, and this "Help" is inside of this version.
with kind regards,
Rogerio.
Old   June 29, 2009, 19:25
ckleanth's Avatar
George
yep, just found the section however still you shouldnt copy paste the manual. lets go to a more relevant question shall we?
dunno m8 just recenly moved to v12 so maybe someone else can help... I dont think you can acess the data realitme without user fortran however I may be wrong
Top 4 tips
Old   July 2, 2009, 23:29
HeKLeR is on a distinguished road
I use xp 64 bit.
Follow the intel installation manual too the T and it should work fine.
Can you compile a fortran test program? If not then cfx5mkext will not work.
HeKLeR is offline   Reply With Quote
memory ms visual fortran 6 vadim Main CFD Forum 0 December 20, 2008 14:01
Intrinsic Procedure 'ISNAN' in GNU FORTRAN 77 hawk Main CFD Forum 1 April 12, 2005 23:13
visual fortran Monica Main CFD Forum 1 August 28, 2004 21:45
Fortran77 or Fortran 90 Swapnil CFX 2 November 26, 2002 16:16
Why Favoring Fortran over C/C++? Zi-Wei Chiou Main CFD Forum 35 September 26, 2001 10:34
