June 22, 2009, 01:50 |
auto-savig the results , .res files
SMN
Rep Power: 17 |
hi friends:
how can i save my cfx results before the run finishes manualy or automaticaly?i mean i want not to loose my results for example when the system turns off suddenly and i want to use my results as the initial file for the next restart run!! |
June 22, 2009, 07:22 |
George
Rep Power: 18 |
obviously you need to set the output control to create bak and what information you want on the res files. with version 12 its a bit of a mess realy to find the bak files. all simulation files are saved (that includes def bak and res files on your temp directory) and once the simulation s finished and saved they are copied on your working directory. i dont particulary like that much automation and I only create the mesh on workbench and fire up cfx on its own.
Top 4 tips 1. Knowledge is everything and Ignorance is dangerous. 2. Understand your limitations and try to eliminate them. 3. Get yerself a bike and hoon the chuffer. You will soon learn why dogs like to hang their heads out the car window. 4. Please before asking any questions on how to run simulations in CFX, go though all the tutorials |
June 22, 2009, 08:10 |
Rep Power: 144 |
You can save backup files (if steady state) or full transient output files (is transient) by the settings on the output tab in CFX-Pre. You can set them by various time increments or iteration number or whatever. If you want to do a backup of a run currently going then press the backup button. That will do a backup file at the end of the current iteration (if steady state) or time step (if transient). Glenn Horrocks |
June 22, 2009, 09:14 |
George
Rep Power: 18 |
glenn i think if you run a simulation within workbench it deletes the backup files once you complete and save a simulation
June 22, 2009, 19:48 |
Rep Power: 144 |
I don't run CFX inside WB. That is one reason why. Glenn Horrocks |
June 24, 2009, 06:06 |
SMN
Rep Power: 17 |
hi:
i have .bak and . trn files...but they can not be used as the initial files for the next restart??? |
June 24, 2009, 09:00 |
Rep Power: 144 |
.bak and .trn files CAN be used for initial conditions, but only if they contain all necessary variables. If you only select a few variables in your trn files then you will not have enough to define an initial condition and it won't work. Glenn Horrocks |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 08:21 |
OpenFOAM15 paraFoam bug | koen | OpenFOAM Bugs | 19 | June 30, 2009 11:46 |
Results saving in CFD | hawk | Main CFD Forum | 16 | July 21, 2005 21:51 |
Export data from several .res files | Nessan | CFX | 2 | April 14, 2004 13:56 |
