importing mesh from Gambit and other software to ansys workbench |
June 1, 2009, 05:39 |
SMN
Rep Power: 17 |
hi:
I have some problems with structured mesh generating in ansys workbench and i want to import mesh from other softwares like Gambit for simulating in ansys workbench as it is possible to import mesh from gambit to cfx in the form of ".msh". Is it possible & how? thx |
June 1, 2009, 19:43 |
Rep Power: 144 |
CFX-Pre can import Fluent cas and dat files and Gambit mesh files. Glenn Horrocks |
June 2, 2009, 04:12 |
SMN
Rep Power: 17 |
hi Glenn Horrocks:
i want to import mesh to ANSYS WORKBENCH for simulating solid models.(not to cfx-pre) Last edited by mortazavi; June 2, 2009 at 08:38. |
June 2, 2009, 11:09 |
George
Rep Power: 18 |
June 2, 2009, 19:58 |
Rep Power: 144 |
I don't know much about importing into WB, but it looks like in V12 you can import CFX mesh files. So you could import the Gambit mesh file into CFX-Pre, generate a CFX def file and that can be imported into WB. In general, the CFX mesh format is read by most of the ANSYS family. The Fluent mesh formats are read by only a few bits of the ANSYS family. So if you can convert your mesh to a CFX def file then you will be able to get it into pretty much anything from ANSYS. I suspect if you are looking to manually edit the mesh (is this what you are planning on doing?) then you will probably want to use ICEM to do this. Glenn Horrocks |
June 3, 2009, 02:05 |
SMN
Rep Power: 17 |
hiiiiiiii:
you can check that the"open" option in wb simulation or wb meshing doesnt contain any def or cfx file format. |
May 30, 2012, 05:36 |
Rep Power: 14 |
hi
plz see this http://www.cfd-online.com/Forums/cfx...tml#post363754 i have other mesh in cfx-pre, when inport mesh from gambit, my mesh lost! |
May 30, 2012, 06:27 |
Peter Galimutti
Rep Power: 14 |
Create a stand alone 'Meshing" component system in WB. When you mesh in Gambit export the file of the filename.dat format. Import into Ansys WB "meshing the 'filename.dat' mesh. Also remember, you can not edit the mesh imported from other grid generation software.
I'm curious what kind of geometry is it? because Ansys Meshing can pretty well handle all solid bodies for nice mesh. Anysys Meshing is also integrated with Mechanical APDL in the form of 'commands' for expert settings. BTW why did you even mention CFX when you want to do structural analysis? You might find better help in the appropriate forums!! Last edited by p.galimutti; May 30, 2012 at 06:43. |
May 30, 2012, 06:36 |
#9 | |
Rep Power: 14 |
i open my design in cfx standard and import new mesh, but i lose my own meshes... |
May 30, 2012, 06:57 |
#10 |
Peter Galimutti
Rep Power: 14 |
I don't know about Gambit; but, see if you are able to export gambit mesh to Icem cfd, and then export it to cfx..in icem you have the option to export mesh for cfx. see the documentation or a tutorial, it's not hard
May 30, 2012, 07:10 |
#11 | |
Peter Galimutti
Rep Power: 14 |
first you said you want to generate a mesh for struct analysis.... now you say you want to create a mesh for cfx... what exactly are you trying to do..and please post according to posting guidelines |
May 30, 2012, 07:15 |
#12 |
Peter Galimutti
Rep Power: 14 |
ANSYS WB MESHING 'OPEN' WILL NOT HAVE ANY DEF OR CFX FILE FORMAT!!!! because wb meshing eventually produces a def file for cfx. it is autonomous and it will not allow any other pre-processing software to import and edit mesh. I see you are trying to generate nice mesh in gambit, but define boundaries in ANSYS WB. Unfortunately as of now you can not do it!
May 30, 2012, 08:38 |
#13 | |
Rep Power: 14 |
http://www.mediafire.com/?6o6o667se6zdbmm |
