Ansys CFX to VTK - Postprocessing results |
March 27, 2009, 09:54 |
Santiago Orrego
Rep Power: 17 |
Hello Guys.
I was wondering if somebody was a script that help me to traduce the CFX results to a VTK format ? Or any body knows a way to do that? Thanks a lot. Santiago O. |
March 29, 2009, 19:03 |
Rep Power: 144 |
Are you using paraview? Not sure of the best way to get stuff into VTK/paraview. CFX can export a number of formats. A quick look suggests Ensight format is a common format between the two packages. Have you tried Ensight format? You can export Ensight format from the solver manager (tools/export results) Glenn Horrocks |
March 30, 2009, 19:46 |
Santiago Orrego
Rep Power: 17 |
Hello Mr. Glenn.
Yes, im working with Paraview. Im workingto export CFX results to paraview. I havent try anything. Ill try Ensight (thanks for the suggestion) and also CGNS format. Ill tell you my results. Santiago |
March 31, 2009, 11:43 |
Santiago Orrego
Rep Power: 17 |
Hello Guys.
Good news!!!!!!!! I made the export from CFX to Paraview. I just exported CFX results to Ensight. In CFX Solver : (tools/export results). Remember to export the data as ASCII. (Its an option of the export tool). Then, I opened the Ensight files with Paraview 3.4. File>open and select the case. Hope it works to you guys. Cheers, Santiago |
October 7, 2011, 08:28 |
#5 | |
Pang
Rep Power: 16 |
Thanks a lot! |
April 17, 2012, 23:12 |
mohammad
Rep Power: 16 |
I also enjoyed this useful post...tnx
June 3, 2013, 10:43 |
stefan
Rep Power: 14 |
I tried the same but it doesn't work.. The export from cfx-solver completed successfully. But paraview shows me this message after loading the case: ERROR: In C:\DBD\pvs-x64\paraview\src\paraview\VTK\IO\EnSight\vtkGeneri cEnSightReader.cxx, line 457 vtkPGenericEnSightReader (0000000009E1DE80): Unable to open file: ...xyz... Warning: In C:\DBD\pvs-x64\paraview\src\paraview\VTK\IO\EnSight\vtkGeneri cEnSightReader.cxx, line 458 vtkPGenericEnSightReader (0000000009E1DE80): Assuming binary file. Do sombody know this problem and could help me please?! Thanks |
June 3, 2013, 10:50 |
Lance
Rep Power: 22 |
I've done CFX to Paraview with Ensight files a couple of times and it has always worked fine for me. Open the .case file in a text editor and make sure that all files/variables are in the same folder.
Are you using Ensight version: Gold and Format: Binary? |
June 3, 2013, 10:58 |
#9 |
stefan
Rep Power: 14 |
I tried the export with all output formats... Ensight 5, 6 and Gold,.. Binary and ASCII
February 18, 2015, 20:37 |
#10 |
Ndong-Mefane Stephane Boris
Rep Power: 12 |
Hello stefan85r,
I am getting the same error with Paraview 4.3.1 on Win7. Do you still have the same issue? did you fix it??? Stephane |
October 16, 2015, 11:48 |
#11 |
Michael Wegrzyniak
Rep Power: 13 |
I was able to work around this problem by ensuring that the file name(s) generated by the export didn't contain any non alpha-numeric characters. For example, the import into Paraview 4.4.0 failed if the file name was "output_2_ensight.case" but worked if it was "output2ensight.case".
I hope this helps. |
I cannot open Ansys CFX in Workbench | Pham Son Minh | CFX | 2 | January 13, 2008 04:33 |
Exporting results from CFX to ANSYS ?? | sohail ahmed | CFX | 1 | December 20, 2007 02:10 |
Problem on mesh import to Ansys CFX 10.0 | Stephen Lau | CFX | 1 | April 18, 2007 04:02 |
ANSYS FLOTRAN and CFX | Paul Atreides | Main CFD Forum | 0 | December 27, 2006 11:23 |
Will the ANSYS - FLUENT- CFX kill freedom of CFD? | Ben | Main CFD Forum | 17 | September 20, 2006 04:36 |
