FSI
Like Tree1Likes
  • 1 Post By mamly
Old   December 16, 2008, 22:46
Default FSI
Netra reddy
I am working with pulsatile flow in a flexible tube model.Designed the tube in ansys workbench and gave the material properties.geometry of the fluid nd mesh is done in Ansys ICEM CFD.when tried to solve the combined in ANsys solver the following error popped up.
Added /FLOW?SOLVER CONTROL/EQUATION CLASS:momentum/TRANSIENT SCHEME/TIMESTEP INITIALISATIONS/Option=Automatic
Processing ANSYS Input File(Running CCL2MF)
Created C:\Documents and Settings\Divya\straight pipe\geoagdb_002.ansys\ANSYS.mf
Starting ANSYS Solver
An error has occurred in cfx5solve: ANSYS Solver terminated unexpectedly with return code 3840
This run of the ANSYS CFX solver has finished.
Could you please say what is the problem.
Old   December 17, 2008, 07:48
Default Re: FSI
brunoc
Check the ANSYS log files located at geoagdb_002.ansys\. They might give you some answers.
Old   February 21, 2012, 02:31
Sulakshan Arya
sulakshanarya is on a distinguished road
"C:\Program Files\ANSYS Inc\v130\CFX\bin\perllib\cfx5solve.pl" -batch
-ccl runInput.ccl -fullname "Fluid Flow CFX_002"
Setting up CFX Solver run ...
| Starting ANSYS Solver |
| An error has occurred in cfx5solve: |
Please tell me what is the problem..
I am doing FSI using ansys workbench.
sulakshanarya is offline   Reply With Quote
Old   February 21, 2012, 11:32
stumpy is on a distinguished road
Take a look at the ANSYS log file. The CFX out file just say ANSYS died.
stumpy is offline   Reply With Quote
Old   February 22, 2012, 01:32
Sulakshan Arya
Hi stumpy, some how the previous problem got solved but now i have a new error could you please tell me whats wrong..
ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| CFX encountered the error: Read. Fatal error occurred when reque- |
| sting Total Mesh Displacement for Interface. |
| Message: |
| cplg_SendCommand failed to send the command: ERROR -- CFX encount- |
| ered the error: Read. Fatal error occurred when requesting Total |
Old   February 22, 2012, 10:27
Same as before - check the ANSYS log file since CFX could not get a mesh displacement from ANSYS (i.e. ANSYS died)
Old   February 24, 2012, 05:44
Sulakshan Arya
No i didn't find anything saying ansys died, or trouble in transferring mesh from ansys... Is there anything else causing the problem???
Old   February 24, 2012, 12:29
The error you posted showed that ANSYS failed:
ERROR -- CFX encountered the error: Read. Fatal error occurred when requesting Total Mesh Displacement for Interface.
If CFX cannot read the displacement, which comes from ANSYS, then it's more than likely that ANSYS failed. You need to look in the ANSYS.stdout file to find out why.
Old   September 22, 2015, 15:30
Default ANSYS Solver terminated unexpectedly with return code 1280
mamly
mamly is on a distinguished road
Hello everybody
I am doing FSI problem
but as soon as I press solve the ansys says:
anybody can help me?
Rabah amina likes this.
mamly is offline   Reply With Quote
User-defined force transfer across FSI interface vivekcfd CFX 7 March 10, 2010 21:43
BCs in an FSI simulation of a flexble pipe vivekcfd OpenFOAM 10 January 8, 2010 05:14
fsi sun Siemens 8 January 20, 2009 00:17
how to extend FSI 2D codes to 3D, need advises abouziar Main CFD Forum 1 May 30, 2008 05:08
FSI on a Rotating Structural Model drgolf CFX 9 August 30, 2007 13:08
