Contour plot with negative velocity
Like Tree2Likes
  • 1 Post By J
  • 1 Post By CycLone
Old   October 30, 2008, 16:08
Default Contour plot with negative velocity
J
Hello hello! I am writing again for the same problem...CFX-Post is not plotting the negative values of the velocity. Consider a plane and you want to create a contour plot on this plane...in some region the velocity is positive and in other regions the velocity is negative...I dunno why but there is no way to say to CFX-Post to plot the negative values of the velocity and show also in the legend the negative values...it is just plotting the positive values cutting the negative...I've done everything...global, local, user defined...no way...doesn't work. Do you have any idea?? I'm going crazy with this stupid problem... PS: I am using the components of the velocity...not the magnitude, so I should see when the velocity is positive and when is negative. Thanks
J
sunil kumar likes this.
Old   October 31, 2008, 09:28
Default Re: Contour plot with negative velocity
CycLone
If there are negative values, Post will plot them. What are the ranges of velocity for each component (hint, go to the variables tab and select a variable to see it's range).
Post does not have a problem with this, so you must be doing something wrong.
-CycLone
Old   October 31, 2008, 12:28
J
The range is -0.0404405 / 0.0477998. For plotting I create a plane, I creat a contour on that plane and I put Velocity w as variable. I tried with global range, local, user defined etc etc...but is not working... Any suggestions?
J
Old   October 31, 2008, 13:48
CycLone
Are you sure you have negative velocity in the Z direction? If the local range doesn't show it, then you must not have negative velocities at that plane location. Post just plots what is there, so there is no reason it wouldn't show it.
Try creating an isosurface of "Velocity w" equal to zero (use conservative, not hybrid values). This will show you where velocity is negative.
-CycLone
Old   October 31, 2008, 14:44
J
Of course I have a negative velocity at that plane!
Old   October 31, 2008, 14:51
CycLone
If Post doesn't show negative velocities, how do you know you it is negative at that location?
Old   October 31, 2008, 15:15
J
Because I exported the data and there are negative values...And the main flow is going in the -Z direction, so...
Old   November 3, 2008, 17:11
CycLone
You exported the data at the plane where you are locating your contour?
Old   November 3, 2008, 17:23
J
Yes...I've done the contour in Tecplot and works perfectly...
Old   November 3, 2008, 17:31
CycLone
So, to get this straight. At the plane of interest flow is moving in the negative x direction at some locations. If you create a plane at this location and plot Velocity u, Post does not plot any negative velocities?
I find it very difficult to believe this is the case; there must be something you have done or interpreted wrong. There is no reason Post would modify the results or otherwise display them differently.
Have you sent you results and state file to ANSYS technical support for advice? Can you post them on an ftp site for forum users to view?
-CycLone
Old   November 3, 2008, 17:38
  #11
J
Believe me...this is the case...Post is cutting the negative values...since I think, after this discussion, that there is a problem in Post I will send that to our technical support. As soon as I can I will let you know the answer, in this post or in another one but always with the same name "Contour plot with negative velocity". Honestly...I am not a stupid Post is doing something strange...
Old   November 3, 2008, 17:46
  #12
CycLone
Hi J,
I don't think you're stupid; I just can't comprehend how this could occur. If the files are small enough, you can email them to me at cyclone_cfd@hotmail.com.
-CycLone
Mfaizan likes this.
[OpenFOAM] basic question contour plot in paraview Kate ParaView 7 July 23, 2020 15:05
How to Contour plot for omega_z ?? snehal OpenFOAM 3 March 11, 2017 06:41
[OpenFOAM] Contour Plot with Paraview jet ParaView 0 August 26, 2010 11:30
contour plot help jesse@uconn FLUENT 0 February 15, 2010 20:05
Velocity plot J CFX 5 October 27, 2008 13:13
