July 24, 2008, 04:09 |
Hexa ICEM CFD
I am trying to generate mesh using Hexa option of ICEM CFD but getting negative determinant for many cells and also negative volumes for several cells. How can i correct this? |
July 24, 2008, 04:19 |
Re: Hexa ICEM CFD
Hi, try to change maximal size of element in problem surface also you can modify your bloking (if negative volumes is a result of so small minimal angles)
July 24, 2008, 07:18 |
Re: Hexa ICEM CFD
If u have several circle curves, u must use o-grid mesh, to avoid bad angles or so small angles. Remake your block, so! Tell us about your geometry. We´re very interesting to know it!
July 28, 2008, 18:48 |
Re: Hexa ICEM CFD
Step through your pre-mesh with scan planes, that should show where it is folding. Also, if you have created a block from vertices, you may have an inverted block, and will need to re-orient the IJK indices.
Wind tunnel hexa meshing in ICEM CFD 12.1 | matheusguzella | ANSYS Meshing & Geometry | 1 | March 14, 2011 16:14 |
prob while exporting icem cfd hexa mesh to fluent | mani | CFX | 4 | March 7, 2007 03:41 |
ICEM CFD (Hexa) - > Phoenics | James Date | Phoenics | 2 | September 2, 2004 15:18 |
ICEM CFD Modules | Boris | FLUENT | 1 | March 12, 2004 14:37 |
Which is better to develop in-house CFD code or to buy a available CFD package. | Tareq Al-shaalan | Main CFD Forum | 10 | June 12, 1999 23:27 |
