June 18, 2008, 14:36 |
problem in prism layer generation
Hi guys,
I follow the tutorial of iCEM 11.0 to generate tetra mesh and then want to creat prism layer. But I fail again and agin with errors like these: face at 118583 173622 230139 has one volume neighbor and no shell element vt1 loc = 15.1891 18.1678 -27.5124 3 elements at face 181849 224649 224804, not all tets PYRA_5 TETRA_4 TETRA_4 PYRA_5 PENTA_6 PENTA_6 PENTA_6 PENTA_6 PYRA_5 TETRA_4 TETRA_4 PYRA_5 TETRA_4 PYRA_5 TETRA_4 PYRA_5 PENTA_6 PENTA_6 PYRA_5 TETRA_4 TETRA_4 some tetrahedra occupy the same volume and that couldn't be fixed .... and 27 more error messages ... orientation errors! writing out prism layer 1 done initializing directions from levelset norm 5805 prism_nodes Assertion failed: has_volume_elements == 0, file compute_marching_dir.C, line 559 This application has requested the Runtime to terminate it in an unusual way. Please contact the application's support team for more information. Application is finished. Error: prism terminated prematurely Anybody has any idea? Thanks!! |
June 19, 2008, 11:51 |
Re: problem in prism layer generation
First make sure your tetra mesh passes all errors and possible problems checks. Sounds like the tet mesh may have some problems.
June 22, 2008, 19:57 |
These sort of errors usually occur when the mesh is not fine enough to resolve the geometry or the underlying mesh is poor quality. The fix is finer mesh and/or better quality mesh. Glenn Horrocks |
March 26, 2010, 05:21 |
Hi
I have had the exact same problem. Unfortunately, I have not been able to resolve this situation. My mesh contains 4 Millions tet elements so I suppose it could be fine enough. But indeed, it works when I ask ICEM to prism only very simple surfaces, so it tends to prove Glenn Horrocks' point. Please let me know here if any solution has been found except a perfect mesh, which usually never happens in industry ---JOKE--- |
March 26, 2010, 06:03 |
Rep Power: 144 |
The solution is training and experience. You can earn a good wage as a CFD engineer and the reason is because it is not easy.
March 26, 2010, 13:34 |
A collegue has found a way to avoid the crash.
This crash happens after extruding the first prism layer because the quality has diminished. Therefore, an easy way to compute prism boundary layer is : - compute only one layer - split it (split prism option) My collegue always used this method so that the prism are more regular and gradients better computed. Hoping this will help, ---JOKE--- |
[snappyHexMesh] SnappyHexMesh - no layer added | bejbro | OpenFOAM Meshing & Mesh Conversion | 5 | February 1, 2020 21:05 |
[ICEM] Fixing tetra Surface Orientations after prism generation | siw | ANSYS Meshing & Geometry | 14 | December 1, 2015 16:54 |
Getting prism to inflate into mixed tet-hex meshes | Joe | CFX | 16 | October 10, 2011 08:06 |
ICEM Prism Layer transition between surface with prism layers and one without | TWaung | ANSYS Meshing & Geometry | 2 | October 12, 2009 15:56 |
problem in solving "wave generation" problem | san | FLUENT | 2 | April 4, 2006 00:37 |
