November 28, 2024, 04:47 |
System Coupling in CFX
Mey
Rep Power: 6 |
I do not have an Ansys Mechanical license, and because my model is a large geometry (a heat exchanger) with many mesh elements, I thought I would simulate the fluid domain and solid domain separately but couple them to see the effect of the fluid domain on the solid. Is there any possibility to couple two CFX models? wishes, |
November 28, 2024, 18:14 |
Rep Power: 144 |
I do not know why you would want to couple two CFX runs. It is far easier to just run it as one big run with all the coupling handled internally.
The heat transfer in models like this typically is small compared to the fluids model, so the full conjugate heat transfer model is probably only a little bit bigger than the fluids only model anyway.
December 2, 2024, 17:45 |
#3 | |
Rep Power: 33 |
If you are modeling conjugate heat transfer, there is ABSOLUTELY no need to use System Coupling.
The problems occurred in FSI simulation with System Coupling module | hermedo | FLUENT | 0 | July 23, 2020 10:00 |
Heat-Fluid System Coupling | arkaragian | ANSYS | 0 | October 13, 2019 11:41 |
Cooling system design with CFX, Mechanics and system coupling | gmingardo | CFX | 12 | December 2, 2016 15:26 |
Which operating system for CFX is the best? | Dr. Bian | CFX | 12 | June 26, 2006 09:58 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 05:07 |
