Turbulence Eddy Freqency bounds error when using single phase flow vs two phase flow
Like Tree1Likes
  • 1 Post By ghorrocks
Old   October 30, 2024, 16:57
Default Turbulence Eddy Freqency bounds error when using single phase flow vs two phase flow
Eman Eal is on a distinguished road
I have been trying to figure out an issue where a simulation runs well when accounting for cavitation via two phase flow. However when I was trying to run the simulation with only the fluid phase I started to encounter a bounds error with the turbulence eddy frequency.
The error is listed below.
Bounds error detected
Variable: Turbulence Eddy Frequency
Locale : Psupply
| ERROR #004100018 has occurred in subroutine FINMES. |
| Message: |
| Fatal overflow in linear solver. |
| An error has occurred in cfx5solve: |
| The ANSYS CFX solver exited with return code 1. No results file |
| has been created. |
Does anyone know what the difference is between the single phase and multi phase turbulence equations that is causing this or have any ideas on how to fix it.
Also does anyone know how to plot the residual values in the cells in CFXpost so that I can know where the mesh is having trouble?
Eman Eal is offline   Reply With Quote
Old   October 30, 2024, 17:26
That is in the documentation - but is unlikely to be a useful path forwards. A more useful path is likely to be this FAQ: https://www.cfd-online.com/Wiki/Ansy...do_about_it.3F
To put the residuals in the res file so you can view the distribution of residuals: In CFX-Pre, go to the output control and in the results tab: select "Output Equation Residuals" and select "All".
Opaque likes this.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
error, multi phase flow, single phase, turbulence
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 10:52
Code release: Flow Transition and Turbulence Chaoqun Liu Main CFD Forum 0 September 26, 2008 18:15
Two-phase/ Single phase mix flow Reza Main CFD Forum 1 August 6, 2003 07:36
How to set phase dependent turbulence models? J.Yang CFX 2 August 29, 2002 16:39
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
