Define a mass flow boundary condition at an interface in CFX Pre-Post |
October 24, 2024, 04:40 |
Mey
Rep Power: 6 |
I would like to simulate the recirculation of combustion products from the surroundings into my car. The combustion products flow through a duct in the surroundings. Due to an air exchange rate in my car (e.g., 30% of my car’s volume), there is a suction effect from the surroundings into my car. My question is, how can I define the exchange rate (in fact, a mass flow boundary condition) at the interface between the surroundings and my car? Could you please tell me if there is a problem with defining such an exchange rate (i.e., through the mass flow boundary condition) in my model? regards, |
October 24, 2024, 04:59 |
Rep Power: 144 |
There are many ways to do this, we need more information to know which way is most suitable.
* Why are you doing this simulation? What are you trying to learn from it? The purpose of the simulation sets what things you need to model. * Please draw a simple diagram of where the air and combustion products flow, and any information you know about it. You have already mentioned 30% volumetric turnover (presumably in some time scale) which could define a flow rate - so where is this flow rate? Assuming this is steady state: for the flow which goes in, where does the flow go out?
October 24, 2024, 05:30 |
Mey
Rep Power: 6 |
The aim is to evaluate the distribution of combustion products in the car. Firstly, I would like to simulate it in a steady state, but I will have to simulate it transient later. wishes, |
October 24, 2024, 05:43 |
Rep Power: 144 |
Can the outside air be assumed to have constant and known combustion product concentration?
If the answer is yes then you do not need to model it and you just have to model the inside of the car. If the answer is no you have to model inside and outside the car and it is a little more complex.
October 24, 2024, 05:54 |
Mey
Rep Power: 6 |
If I understand your question, I want to see the distribution both outside and inside. May you please help me how I can model it?
bests, |
October 24, 2024, 06:03 |
Rep Power: 144 |
OK, if you want to model both inside and outside:
I assume that the air exchange is done actively by the HVAC system in the car (filters, fans, ducts etc) and passively by leaks and open windows. I would model the inside air domain and outside air domain. The outside air domain would have whatever external conditions are present (combustion products, air velocity etc). * Things like open windows are modelled by simply having a connection from the inside to outside. * Air leaks (which I assume air direct connections which are too small to resolve with the mesh) are modelled by putting an artificial pipe connecting inside and outside which has an equivalent resistance to the resistance of the leak. You might want to out a porous volume to do this, or maybe a source term. * The HVAC system is a little more complex. You need to replace the HVAC system with an artificial pipe connecting inside and outside with a source term in it to drive the flow. The source term is set up to match the system characteristic of the actual HVAC system, from the external air intake through the filters, fan and into the passenger compartment. You have mentioned that you know the flow rate - this is a very simple system characteristic which can be implemented with a source term or an interface with a defined mass flow.
October 24, 2024, 06:13 |
Mey
Rep Power: 6 |
a Wonderful description.
If I understand you correctly, in this case, I should define a mass flow in my interfaces for the exchange rate, which is known. As you mentioned, the air exchange is done actively by the HVAC system in the car (filters, fans, ducts, etc.) and passively by leaks and open windows. In this model, for some reasons, I simplified my model and I have just two interfaces, which I drew in the sketch. Isn’t it? bests, |
October 24, 2024, 06:19 |
Rep Power: 144 |
At the simplest level you could use two connections.
But this does not model the effect of several factors: * Your HVAC system probably has several air vents, not just one. So air is entering the passenger compartment at many locations. * The leaks are all over as well. They will be through the firewall, into the boot/trunk, out the door seals (if they are a bit dodgy), and all over the place. Replacing all those inlets and outlets with a single inlet and outlet is a big approximation. I suspect for what you are trying to do it would introduce unacceptable error, so you need to model enough inlets and outlets that you capture not only the flow rate, but the distribution as well.
October 24, 2024, 06:46 |
#9 |
Mey
Rep Power: 6 |
Surely, it is highly inaccurate. I will improve my model and consider more details later.
I have another question. I would like to build the product distribution like the reality in my simulation and also reduce my simulation time. When I simulate the model transient and I know the change of combustion product concentrations over time, what should I do (besides adjusting the boundary conditions and geometry accurately) to get the correct result? My question is about CFD topics. I need to know how I should evaluate the mesh quality and the Time Step Size required to reach a correct result. |
October 24, 2024, 06:49 |
#10 |
Rep Power: 144 |
Starting simple and increasing the complexity and accuracy as you progress is a sensible path forwards.
What is the distribution of combustion products?
October 24, 2024, 06:54 |
#11 |
Rep Power: 144 |
You do not normally do mesh quality checks for a simulation, you generate the best mesh you can. What you check is the mesh size.
To do this is you run a baseline simulation and extract the key variable from it. In your case it could be the concentration at some location. Then do a new mesh with the element edge length halved (so a hex would become 8 hexes, a tet becomes 5 tets - so you would expect to have between 5x to 8x the number of elements) and simulate that, extract the key variable. Compare the key variable from the baseline mesh to the finer mesh. If they are the same within a tolerance you are happy with then the baseline mesh is acceptable for results. If not then take your fine mesh and halve the element edge length again and repeat the process until your results converge to within an accuracy you are happy with. You will often find this results in very, very big meshes. That is why people build supercomputers to run CFD.
October 24, 2024, 07:30 |
#12 |
Mey
Rep Power: 6 |
Hello Again,
I defined a user function through Interpolation (Data Input) User Functions for my combustion products’ mass fraction change over time (e.g., CO) (see photos). However, when I import it into my boundary condition, I get the following error: Bad expression value 'CO( )' detected in parameter 'Mass Fraction' in object '/FLOW:Flow Analysis 1/DOMAIN:Surrounding/BOUNDARY:Abgasin/BOUNDARY CONDITIONS/COMPONENT:CO'. CEL error: In the expression assigned to 'Mass Fraction', the function 'CO' is called with the wrong number of arguments (0 - expected 1). where is the mistake? |
October 24, 2024, 19:35 |
#13 |
Rep Power: 144 |
Where you call the function CO(), that should be CO(t).
Note that your interpolation function appears to have values up to 4846 in it. Mass fractions just go from 0 to 1, so 4846 is not a valid mass fraction. Check your interpolation function is using the correct values.
October 26, 2024, 03:07 |
#14 |
Mey
Rep Power: 6 |
I defined a mass flow (exchange rate) of 0.009 kg/s for additional interface models. As can be seen in the photo2, I have two interfaces, one at the top and one at the bottom. The problem is that even with a very small value (0.00001) set for the domain interface target value in the convergence criteria in CFX-Pre/Post, I get a lower mass flow (0.001 kg/s) at my interfaces. There are two possibilities: 1) My calculation has not converged (see photo 3), although the change in mass flow is slow, or 2) my boundary condition is not correct. I would be happy if you could give me feedback. bests, |
October 26, 2024, 03:16 |
#15 |
Rep Power: 144 |
That sure does not look converged. You will have to run it longer. Note the residuals and imbalances are the normal things to look at to judge convergence.
I would expect this simulation to converge slowly as you have two very different time scales present. The short time scale is the time scale of the flow, and the long time scale is the combustion products. If you use the default time step size it will give you a very small time step size because of the short flow time scale - which will result in very slow convergence of the combustion products. You will probably want to increase the time step size to speed this up. And note this only works for steady state flows. For transient flows you are forced to use a time small scale so the fast flow features are resolved and the combustion products will converge very slowly.
October 26, 2024, 03:30 |
#16 |
Mey
Rep Power: 6 |
I appreciate your fast feedback.
I simulate a steady state first, followed by a transient state. I increase the time scale size. For your information, I define the combustion product as a material (variable composition mixture). I do not simulate combustion. wishes, |
October 28, 2024, 09:30 |
#17 | |
Mey
Rep Power: 6 |
And also, should I define the mass flow rate for both interfaces or just one of them? Does the sign (positive or negative) of the mass flow rate play a role in this case? |
October 28, 2024, 17:33 |
#18 | |||
Rep Power: 144 |
* Mesh quality makes a massive difference * Converge as tight as you need, and no tighter. Use a sensitivity study to determine how tight you need to go. * Use a time scale factor and/or larger time step size in steady state runs to speed things up * In transient runs determine the time step size by another sensitivity analysis, or use adaptive time stepping homing in on 3-5 coeff loops per iteration. * Mesh quality makes a massive difference. It is important enough to say it twice. Quote:
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 14:55 |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 11:00 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 18:44 |
CFX13 Post Periodic interface | EtaEta | CFX | 7 | December 8, 2011 18:15 |
