October 4, 2024, 04:40 |
Transient open channel flow simulation
sanjay
Rep Power: 2 |
I have only inlet boundary expressions which are time dependent and other boundaries are open, sidewalls, bottom wall and outlet, then how write expression for outlet pressure? Please keep it mind that pressure at outlet will not be zero.
October 4, 2024, 05:54 |
sanjay
Rep Power: 2 |
I used Ansys-cfx tool
October 4, 2024, 10:55 |
#3 | |
Rep Power: 33 |
Have you done the free surface modeling tutorial?
October 4, 2024, 11:08 |
sanjay
Rep Power: 2 |
Yes I did surface flow simulation (steady case) using Ansys-cfx
October 5, 2024, 06:53 |
Rep Power: 144 |
Doesn't that tutorial example show you how to implement a boundary condition by CEL?77
October 5, 2024, 07:08 |
sanjay
Rep Power: 2 |
I know how to write CEL expression. But I don't have velocity and depth data for outlet boundary and other boundaries are set. I want outlet pressure and water volume fraction for outlet for transient multiphase open channel flow.
Inlet boundary expressions are, massflowrate and AVFinlet, WVFinlet. |
October 5, 2024, 07:15 |
sanjay
Rep Power: 2 |
Here AVFinlet means air volume fraction at inlet and Wvfinlet means water volume fraction at inlet. I am doing multiphase transient simulation in open channel for fast flowing floods. I have inlet boundaries only, then I how set outlet boundary in ansys-cfx.
I define user function and expression at inlet for mass flow rate and pressure(time dependent). I need values for outlet only, how set it without velocity and depth . |
October 5, 2024, 08:00 |
Rep Power: 144 |
You have to know something at the exit boundary so you can define a boundary condition. If you do not know anything at your proposed boundary you cannot use it and must move it to another location where you do know the conditions.
Maybe you should add a basin to collect the flow and you can put a boundary on that.
October 5, 2024, 12:31 |
#9 |
sanjay
Rep Power: 2 |
It is mandatory Boundary (Outlet) and our case of unsteady flow. So I am looking for wright approach to simulate this open channel multiphase transient flow problem.
October 6, 2024, 20:20 |
#10 | |
Rep Power: 33 |
In the simple cases of open channel flow I did 30+ years ago, I recall I always had the depth (pressure either static or total). You cannot try to model something w/o knowing the states upstream and downstream.
October 7, 2024, 04:06 |
#11 |
sanjay
Rep Power: 2 |
Ok..I will try
Possible BCs for open channel flow simulation using interFoam | Wenhao Dong | OpenFOAM Running, Solving & CFD | 0 | July 31, 2024 03:32 |
Using PengRobinsonGas EoS with sprayFoam | Jabo | OpenFOAM Running, Solving & CFD | 36 | July 16, 2024 04:52 |
VOF open channel flow simulation | masoud.ravan | Fluent Multiphase | 0 | February 25, 2017 04:04 |
Enabling Open Channel Flow Sub-Model in Mixture model | cod213 | FLUENT | 0 | January 10, 2017 14:40 |
Open channel flow simulation using VOF | rsaha | FLUENT | 5 | April 10, 2016 18:28 |
