A wall has been placed at portion(s) of an OUTLET
Like Tree3Likes
  • 1 Post By Opaque
  • 2 Post By zacko
Old   August 1, 2024, 13:01
Default A wall has been placed at portion(s) of an OUTLET
Shreyash
Shreyashv is on a distinguished road
I am doing a CFD of a turbofan blade, where im analyzing a single blade of 20. I have given inlet and outlet static pressure of 1 bar to both. Still i get a notice of a wall being placed for more than 50% of the inlet and outlet area to prevent flow leak into the domain causing an area of re-circulation.
i tried playing with the boundary conditions to changes the pressure but none work.
can anyone help me in this?
thank you
Shreyashv is offline   Reply With Quote
Old   August 1, 2024, 14:15
Opaque will become famous soon enough
thank you
Do you understand how to choose boundary conditions for fluid flow?
You cannot set a model with static pressures on both inlet and outlet. It would be ill-conditioned.
Shreyashv likes this.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Opaque is offline   Reply With Quote
Old   August 1, 2024, 17:13
Daniel
zacko is on a distinguished road
You should also take a step back and understand the basics, what this blade will do in general before taking on CFD simulations. How will the fluid behave? What will the blade achieve? Pressure decrease / increase? If you simply answer these simple questions you automatically understand why pressure in-out boundary condition simply doesn't work.
Opaque and Shreyashv like this.
zacko is offline   Reply With Quote
ansys, boundary condition, cfx 11
[snappyHexMesh] How to draw a 3D-Drawing for Meshing Kahnbein.Kai OpenFOAM Meshing & Mesh Conversion 4 June 15, 2021 13:16
outlet pressure Boundary settings -velocity streamline under ambient temp.conditions Vishnu_bharathi CFX 12 November 21, 2017 07:56
Radiation interface hinca CFX 15 January 26, 2014 18:11
[ICEM] Export ICEM mesh to Gambit / Fluent romekr ANSYS Meshing & Geometry 1 November 26, 2011 13:11
Combining BCs: wall - outlet. Boundary layer disappears MartinaF OpenFOAM Running, Solving & CFD 1 July 20, 2009 19:14
