Jump in inlet total pressure when using a user routine in CFX |
July 26, 2024, 08:19 |
Rep Power: 10 |
Hi everyone,
I have some problems using a self written Fortran user function for inlet total pressure in CFX. I have written an iterative function, that is changing my inlet total pressure depending on downstream conditions. The script itself seems to work fine. I monitored the output (the value I set in CFX as inlet total pressure) of the script in CFX and it is exactly what I wanted it to be. The problem is, that the total pressure at the inlet is not even close to this value. CFX is placing walls at 99%-100% of the inlet. I tried some different things until I'm now at a point, where I have no idea how to go on. The last try was having a CEL function that has a constant total pressure for the first 50 iterations and after that switching to my function. In my function the total pressure was also hold constant for another 50 iterations (up until time step 100) with the same value as before. I have a monitor point for that CEL function that switches between the constant value and my function, that gives back the same constant value. The output of this monitor point is perfectly constant from timestep 50 to 51. Up to timestep 50 the massFlowAve total pressure at the inlet is close to the constant value I set up (without any walls put at the inlet). At the point I switch to my script, the massFlowAve total pressure jumps within 2-3 timesteps to -10^20 Pa, which leads to a crash... I'm not wondering why it crashes, that is clear with that jump. But I have no idea why the input value remains constant but for the simulation this makes such a huge difference... It is all done in a steady state simulation (Iteration is only done to match given conditions that are measured downstream) with Version 2024R1. This is my first time programming and using a user routine in CFX, so maybe there is something I completely misunderstood... Unfortunately I cannot share a picture of the model or a full CCL. If it is not clear what I mean, let me know and I will build a simplified version/picture. Thanks! |
July 26, 2024, 09:10 |
Rep Power: 33 |
You may need to post your "User Fortran". It would be impossible to know if there is an illegal memory access or an incorrect setting in your code w/o looking at it.
July 26, 2024, 10:49 |
Rep Power: 10 |
The code is shown below.
Im running this in "Mode==1". I deleted the part for other modes to make it a bit shorter Interval is 100 ValIni is the same value, I use before in the CEL equation. FileNo is 1. This option is just there so I could use this script for different iterations within one run (if needed). In this simulation I'm using it only for my total inlet pressure. When it crashes at timestep 53, I think all other input values should not be relevant. Code:
#include "cfx5ext.h" dllexport(usr_iterative_bc) SUBROUTINE USR_ITERATIVE_BC ( & NLOC,NRET,NARG,RET,ARGS,CRESLT,CZ,DZ,IZ,LZ,RZ) IMPLICIT NONE C C ------------------------------ C Argument list C ------------------------------ C INTEGER NLOC, NRET, NARG CHARACTER*(4) CRESLT REAL RET(NLOC,NRET), ARGS(NLOC,NARG) C INTEGER IZ(*) CHARACTER CZ(*)*(1) DOUBLE PRECISION DZ(*) LOGICAL LZ(*) REAL RZ(*) C C ------------------------------ C Local Variables C ------------------------------ CHARACTER (len=16) FNI INTEGER Iteration, Interval, Mode, Direc, FileNo DOUBLE PRECISION ValIni, ValDif, MaxStepAbs, MaxStepRel, NewVal REAL InData, InIter LOGICAL exists C --------------------------- C Executable Statements C --------------------------- Iteration=ARGS(1,1) Interval=ARGS(1,2) ValIni=ARGS(1,3) ValDif=ARGS(1,4) Mode=ARGS(1,5) MaxStepAbs=ARGS(1,6) MaxStepRel=ARGS(1,7) Direc=ARGS(1,8) FileNo=ARGS(1,9) IF (FileNo==1) THEN FNI='IterValLastA.txt' ELSEIF (FileNo==2) THEN FNI='IterValLastB.txt' ELSEIF (FileNo==3) THEN FNI='IterValLastC.txt' ELSE FNI='IterValLast.txt' END IF IF (Mode==1) THEN INQUIRE (FILE = FNI, EXIST = exists) IF (.NOT. exists) THEN NewVal=ValIni OPEN (UNIT=7, FILE = FNI, ACTION='WRITE') WRITE(7,*) (Iteration, NewVal) CLOSE(7) ELSEIF (Iteration<2) THEN NewVal=ValIni OPEN (UNIT=7, FILE = FNI, ACTION='WRITE') WRITE(7,*) (Iteration, NewVal) CLOSE(7) ELSE OPEN (8, FILE = FNI, STATUS='OLD', ACTION='READ') READ(8,*) InIter, InData CLOSE(8) IF (InIter<Iteration) THEN IF (MODULO(Iteration,Interval)==0) THEN NewVal=InData+(ValDif/abs(ValDif))* & min(abs(ValDif)*MaxStepRel,MaxStepAbs)*Direc OPEN (UNIT=7, FILE = FNI, ACTION='WRITE') WRITE(7,*) (Iteration, NewVal) CLOSE(7) ELSE NewVal=InData END IF ELSE NewVal=InData END IF END IF ELSE NewVal=ValIni END IF RET(1,1) = NewVal END |
July 26, 2024, 19:21 |
Rep Power: 144 |
I would do some basic debugging: Put lines in your code which output the values of key variables (either to the CFX output file or a separate output text file) and look at what all your variables are doing each iteration to check it is doing what you expect.
Your line: NewVal=InData+(ValDif/abs(ValDif))* & min(abs(ValDif)*MaxStepRel,MaxStepAbs)*Direc Looks very strange. What is this line trying to achieve? Is this going to make the value of NewVal jump around? If so this is always going to be hard to numerically converge. You might need some under-relaxation or other numerical techniques to get it to converge.
July 29, 2024, 08:45 |
Rep Power: 33 |
Your code seems to assume to be called with an NLOC = 1 at all times.
Are you certain NLOC is 1 for all calls? You need IF (NLOC .NE. 1) STOP, and see if that code works.
August 5, 2024, 09:44 |
#6 | ||
Rep Power: 10 |
Thank you for your responds. I was a week out of office and therefore had no chance to answer.
The idea behind this line is to change my inlet condition regularly but not with every iteration. I want to set a constant total pressure at an interface downstream of the inlet. Therefore I wait several iterations so that my changes at the inlet can propagate to this interface and become (more or less) stable at this position. To avoid large jumps at the inlet, the change is limited by the given value "MaxStepAbs". I had a similar code as a CEL function, which worked fine. There was just the problem, that I coudn't hold the value stable since I had no informations of prior timesteps. With the external file I tried to eliminate this problem. Quote:
At this point I don't know how the solver interacts with the script and how it differs from just using a CEL expression. What I want to get, is a single pressure value to use as inlet condition. |
August 6, 2024, 09:35 |
#7 | |
Rep Power: 33 |
As a debugging step, you should start by running the NULL case, i.e. send back EXACTLY the same value for all calls. Separately, run the case using the same value w/o UserFortran. Both simulations should be identical at every iteration; otherwise, the UserFortran code is introducing some error.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum. Last edited by Opaque; August 6, 2024 at 19:45. |
August 7, 2024, 11:01 |
Rep Power: 10 |
I already read that the solver is calling the script as often as it needs it but I expected that this would be with NLOC=1, like "asking" for a single value as it would be when I just directly type in a single value for inlet pressure.
I just tried this by setting the value of "Mode" to 3. Therefore, it should give "ValIni" back. "ValIni" is a constant value without any change during the process. The behavior in the simulation is similar as before. In parallel I also used the same value directly as input (without any CEL or FORTRAN code involved). It behaves different and in a way I expected it to do. So there seems to be a problem with my script. For me, the problem seems to be in the way how my script is communicating with the solver, since the values I write to the external file are exactly as I want them to be... I'll have a look into this when I have some time. If anyone has an idea what to change it would be great. Tanks a lot |
August 7, 2024, 12:55 |
#9 | |
Rep Power: 33 |
In your code, check how many locations are being provided -> NLOC. Your responsibility is to fill in ALL the entries; otherwise, the returned array is uninitialized.
August 8, 2024, 09:09 |
#10 |
Rep Power: 10 |
In general, I know that, but to be honest, in this case I perhaps didn't think about it properly... And that was the problem here. If I return not just a single value but a vector, everything now works the way I want it to.
I don't know what cfx does when the wrong number of values are returned, but if the missing entries are treated as zero, it would make perfect sense that walls were built on my input. I feel a bit dumb now after seeing what went wrong, but many thanks for the help anyway. |
How to make user routine just be called once in one time step? | doublestrong | CFX | 3 | October 21, 2018 23:06 |
Reversed flow using pressure inlet and outlet? | here_for_help | FLUENT | 0 | September 28, 2018 15:20 |
Total pressure in CFX | famarcfd | CFX | 0 | June 17, 2011 10:33 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
