May 26, 2024, 03:49 |
Automate Ansys Workbench
Lucas
i have some problems to automate Ansys. I am completly new to Ansys by the way. My task is to simulate a large number of centrifugal compressors. For that i have a Matlab tool, that generates me the needed .inf files for Turbogrid. Afer that i want CFX to calculate the efficiency. Now i need to automate Ansys to make the same steps for all the generated .inf files. The best way i found so far, is to create a session file in the Workbench and record my steps. Is there a better way than this? And is it possible to control this from Python? Any help is appreciated. |
May 26, 2024, 04:50 |
Rep Power: 144 |
Make sure you are talking about the correct software names.
ANSYS Workbench = Tool used to control all ANSYS products (from FEA to CFD, electro magnetics and everything else) CFX Pre = pre processor for CFX. CFX Pre can use session files, workbench cannot. Are you actually using CFX-Pre?
May 29, 2024, 06:17 |
Lucas
Thank you for answering.
I got that term wrong, i recorded a journal in the workbench, where i set up a trubogrid and a cfx instance. That works atleast if i use the same .inf file again, didnt testet what happens when i open another .inf file with the same journal. As far as i know i can adjust the journal file in text editor after recording it. Is there a list of commands i can use, for example to change a setting in CFX-Pre without recording the whole journal again? Couldnt find anything like that in the Ansys help documents. My method now would be, that, after the first iteration, i open this journal file with python and change the path to my next .inf file in it and start the journal again. I just dont know if that is the easiest way, or if i just dont know about a feature that would help me. |
May 29, 2024, 06:26 |
Rep Power: 144 |
I use workbench as little as possible. I use the CFX tools stand alone almost always as you have much more control over what is going on, and it crashes less.
If you are using turbogrid, CFX-Pre and the CFX-Solver then I would automate that myself using a batch file (if you are windows) or the equivalent in LINUX. All these tools can be called from the command line, and controlled using session files, CCL and other methods.
ansys, automation, cfx, worbench |
Ansys Installation on Docker Container | mohsen.shiea | ANSYS | 11 | March 14, 2024 11:18 |
Run Ansys Journal Files in an opened Workbench from an external Python Script | LStar | ANSYS | 2 | March 27, 2023 02:42 |
Possibility to use Ansys workbench for coupling Fluent and Maxwell in Two computers | vanhoivanbinh | ANSYS | 6 | December 15, 2022 06:37 |
polarization of permanent magnets in cylindrical coordinate system in ansys workbench | J.sepaseh | Electromagnetics | 0 | December 19, 2019 13:34 |
Pro/E to ANSYS Parameterization Guide | Trues | ANSYS | 4 | April 18, 2018 05:52 |
