Can ANSYS CFX solve multiphase flow using VOF method? |
May 20, 2024, 23:11 |
Xiangjie Qin
Rep Power: 3 |
Can ANSYS CFX solve multiphase flow with VOF method? Is this equivalent to the free surface model in the homogeneous model?
May 21, 2024, 02:03 |
Rep Power: 144 |
CFX can solve free surface simulations with the free surface model in the homogeneous model. It is not the same as a VOF model, but similar.
June 6, 2024, 05:35 |
Xiangjie Qin
Rep Power: 3 |
Thank you very much.
But I found that many published papers explain that they use the VOF method to solve two-phase flow in CFX. Is this appropriate? The VOF method is widely used. |
June 6, 2024, 05:43 |
Rep Power: 144 |
The original 1976 publication which first defined the VOF approach and CFX's inhomogeneous model are similar in overall approach, but quite different in how they achieve it. If by "VOF" you mean a fixed mesh with a volume fraction equation and the surface is reconstructed from the volume fraction field then I guess you can call CFX's approach VOF.
Ncrit for a glider Xfoil. How to use it. GPT4 answer | AlanMattanó | Main CFD Forum | 0 | April 10, 2023 12:16 |
unable to run dynamic mesh(6dof) and wave UDF | shedo | Fluent UDF and Scheme Programming | 0 | July 1, 2022 17:22 |
Multiphase VOF - Flow in a Channel | harsha28 | Fluent Multiphase | 1 | July 8, 2020 16:39 |
capability of CFX to solve low Re numbers- Creeping flow (Stokes flow) | JohnPuentes | CFX | 25 | August 6, 2014 08:25 |
Solve Flow or VOF simultaneously ? | Ramsey | FLUENT | 1 | February 16, 2011 13:16 |
